741 - 745 of 745 Posts
KB8C-67-XA1 - 2017 MY CX-5. In Europe it was not used in CX-9
KD7J-67-XA1K (Strong radio wave) - 2021-2022 MY CX-9.
K131-67-XA1J (Weak radio wave) - 2021-2022 MY CX-9.
So yeah, considering your car is not 2017 MY CX-5, and you installed radar from it into CX-9, which never had such radar from factory (at least in Europe) - it might be the reason of your issues.
TAY1-43-7A0 - ABS in 2021-2022 MY CX-9 with support of Full Range ACC.
I’ve just installed the KD7J-67-XA1K radar and tried every possible value for FB-05 and I cant get away from these errors:
• U2300:56 – Invalid configuration
• C0063:54 – Missing calibration
As a note i haven’t installed the wheel buttons for MRCC, does this may lead to the above error?
Not sure, but have you changed the values in 720-04-23?
owns 2015 Mazda 3 Touring+
Yes I Did. I tried with the option for MRCC, not the ones that states MRCC with ISA or ASL.
What else could be happening? I was considering changing the car's country to match the radar's country (USA). If that's the case, I would need to adjust two parameters on the IC, correct? 720-01-01 and 720-04-11 right?
Try these values in BF-05:
Those 3 options are the ones that CX-9 with MRCC have from factory.
I hope you know what BF is and where to put those values.
720-04-23 B4 has value 31 in all of those cars
So you've tried all these options?
Have you performed SBS/MRCC and ABS relearn after each try?
