*10/20/2020 update
I updated the list of parts required and included a wiring diagram
I decided to retrofit my Mazda 3 2018 with MRCC
After some research yesterday I finally complete the retrofit
Mazda 3 2017/2018 parts required
The Radiator support core for the non MRCC model is different and is missing the bolts to attach the brackets. so I had to think on a solution for this.
so I made the nuts with a M6 rivet nut kit that I ordered on amazon
then I had to do the wiring. so I added two lines for the can hi and can lo on a joint connector that is located near the windshield water tank.
add ground and +12v ignition from the correct circuit.
I also added the as-build values for mrcc and distance support.
72004182845F0BF0665
72004230000BF095066 (lim&mrcc)
finally Calibration must be done using FORSCAN or IDS
Radar Unit | BAEK-67-XA1E / BAEK-67-XA1C / BAEK-67-XA1E / BAEK-67-XA1B | 1 |
racket Radar Sensor | b63c67xa2 | 1 |
Stay Bracket | ghp967z71 | 2 |
Controller | ghp967ya0 | 1 |
Bracket Rad.Grille | b63c50716 | 1 |
Cord Short | ghp967sh0 | 1 |
Rear Channel Upper Bolt | 997400510b | 6 |
Lock Support Bolt | 9kk800620b | 8 |
Ornament | dd2f51730 | 1 |
Switch Steering | b68t664m0a | 1 |
Lower Plate | bbm468d42 | 2 |
72004182845F0BF0665
