41 - 60 of 115 Posts
I have found the exact spot where the noise is coming from. It looks like the window but it is not. It seems to come from the top but it is only sound propagation. The culprit is the door lock.
Sorry for the photo, it's just an example.
As a demonstration try to knock on the open door and you will not have vibrations. Close the door ajar and the vibrations will start as soon as the lock engages the b-pillar. With the door ajar, you can understand exactly where the noise is coming from.
Do you possibly have a fix ?
Thanks
I have found where to put a piece of foam to stop the rattle. Is not a real solution because Is very ugly to see it when the door is opened. I drive for 100km with foam a no rattle...is a dream run without any annoing sound.
I am investigating why this piece of foam stop rattle and fix it....if i will not able to fix the rattle i will explain at dealer what i do and hope he can fix it. If anyone is interested i can publish a photo.
I think that i have found the culprit!
No rattle with this easy fix! This Is a temporary fix to show you where put the foam. The solution Is fill this plastic "bag".
PS: try this and thanks me for the rest of your Life :D
I have put Meg's tire Endurance gel on same place where @ikxdf put foam and also where front door rubber seal contacts back door rubber seal and for now no probs, it will be washed out for sure but it will confirm that these locations are making noise - for now it seems so, as there is no noises.
Maybe it would be most easier to permanently glue it.
Sent from my LYA-L29 using Tapatalk
I have put Meg's tire Endurance gel on same place where ikxds put foam and also where front door rubber seal contacts back door rubber seal and for now no probs, it will be washed out for sure but it will confirm that these locations are making noise - for now it seems so, as there is no noises.
Doors trims was my first check but after some test i understand Is not the correct Place.
But there Is a correlation from front and rear door: from externat if you punch the front Door you can hear rattle. If you open the rear door rattle disappear. Put foam like my post fix the issue i don't know why and...i don't want to know why! 😅
Rattle Is gone away and i'm super Happy!
I applied foam in this exact same location. You know you can stick your foam vertically behind the rubber so it will look nice =p
I must say, I am not sure if this is going to fix it in the long run though. Do report back once you drive the car for a month or 2
yes, i have write this: This Is a temporary fix to show you where put the foam.
Now i have filled the empty in the back of the rubber. Long run without issue!
I fixed mine so far by sticking some foam double sticky tape between the inner metal door and rubber moulding. I saw the car already has a thin piece of black foam there so I just doubled up.
I was thinking of doing this also. It is at the very upper corner left just below the window. This gap appears bigger on the drivers side than the passenger side. Not sure what is going on here.
please can you post a photo of the place where you are talking about? i am not able to understand where it is.
Sorry no pic right now. But it was a misaligned clip that the window tint people didn't put back correctly.
I had to pull the door card off, remove the upper left corner clip out of the door frame. Slide it onto the door card and then push everything back on that way. It's all good now. There's a video on YouTube about this special clip.
Sent from my SM-G991U using Tapatalk
Is not my case. My car is brand new and i fixed the rattle as you can see some posts ago.
I want to undrestand where is the place for double spacer you are talking about with this user
i want to check if your fix is better than mine.
Discussion starter · #57 ·
I actually haven't been listening for it recently. I noticed way more in the winter early mornings when its dead quiet outside. Also the rattling from my glasses in the cubby overpowers every other rattle lol.
