6,081 - 6,100 of 7,282 Posts
Hi! In my mazda 3 BL 2009 has a lot of unnecessary features enabled. Some features are not enabled that I would like to enable.
Does anyone have a description of the blocks, maybe even a description of the functions, for my Mazda?
Hello everybody!
I recently installed the door handles, antennas, buzzer and the module for the operation of the "advanced keyless system". Everything works perfectly, with the exception of the unlock mode, because regardless of the option i choose, it always unlocks all the doors ... I wish I could only unlock the driver's door by pressing the button once ...
Has anyone installed this system successfully getting the unlock mode to work?
I own a Mazda 2
This is my SSU config
;Block 1
731G1G14420C0042183
731G1G2000919357002
731G1G30020005C
;Block 2
731G2G1980400D7
Regards!
I believe that this option is not possible to configure via ASBuilt - I only know of "unlock all doors". Would be happy to hear/read here of other info from others... my CX-5 has AKE from factory, but it also unlocks all doors at once.
Hi Tristan!
Thank you so much for your answer!
From what I understand, so your door opener doesn't work like in this video?
Regards!
I just had a look at your values and what states the AKE tutorial of SergSlim... most of the values you already activated... if I were you, I would try to change the following values additionally:
731-01-01 B2 b2=1 and b4=1 - perhaps this 2 step unlock mode is a pre-requirement for the unlock mode of the remote of 731-01-03 B1 b3/b2 (10 - 1x Driver door / 2x All doors).
New value to test: 7731G1G14420D4042197
Edit: Have you checked the MZD menu, if there is a new menu/list entry to change the unlock mode? Perhaps there is a new one.
Who knows where the setting is stored, which is responsible for the strategy of reading the signs and the limit of MRCC speed?
for Europe the MRCC limit is 200km/h
for USA
the MRCC limit is 145km/h
for Japan
the MRCC limit is 100km/h
signs are recognized by TSR are different too
282842
I just got down to the car to try this change, but got the following error in Forscan :(
282859
282860
The menu appears to me from the moment I activated the advanced system, but even if I select the second option, the system continues to open all the doors, emitting two "beep" sounds.
282861
282862
PCM.
I live in Japan and MRCC limit modified to 200km/h by changing the data in PCM.
for USA
for Japan
I used the tool for ECU tuning.
Not As-built, Binary Data from PCM and modify data like tuning for more power.
How did you modify the PCM data? Via ForScan? Which ASBuilt-values have to be changed? Or is it a module setting, which you can change via some kind of service procedure/feature setting change?
No special equipment is required, but you need a J2534 device, software that can read and write PCM, and a binary editor.
It's a lot more difficult than rewriting As-built, and if you fail, your car will die.
I have skills in working with binary files since the time of writing patches for phones firmware (Siemens/Samsung), but I need a set of initial knowledge, I would be very grateful if you will describe the process in details, ideally with photos and videos.
It is also not clear how you found out where and what to edit, where the checksums are, without insider information, in my opinion, this is practically unrealistic.
But since you are from Japan, it is quite possible that you can become our insider and open the secret door of new discoveries for us.
