1 - 20 of 6312 Posts
Banned
With a cruise like understood. Has come time for other useful functions.
I ask all who have a desire to connect to study.
Study SSU:
731-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B1 - it is (in BIN):
b7 - 0 or 1 = function is not known
b6 - 0 or 1 = function is not known
b5 - 0 or 1 = function is not known
b4 - 0 or 1 = 0 - I-Stop OFF, 1 - I-Stop ON (Tested on CX5)
b3 - 0 or 1 = function is not known
b2 - 0 or 1 = function is not known
b1 - 0 or 1 = function is not known
b0 - 0 or 1 = function is not known
B2 - configuration mode wireless control (step-by-step opening):
b7 - 0 or 1 = 0-W/O Advanced Keyless Entry; 1-W Advanced Keyless Entry
b4 - 0 or 1 = 1-W Unlock mode (2-step); 0-W/O Unlock mode (2-step)
b2 - 0 or 1 = 1-W Unlock mode (2-step); 0-W/O Unlock mode (2-step)
731-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
B0 - it is (in BIN):
731-01-03 B0 B1 B2 B3 (checksum) in HEX
B0 - wireless mode lock/unlock is ONLY displayed on monitor (for example it is possible to configure only display the "unlock Mode"(step-by-step opening) or together with "Lock when leaving car":
b6 - 0 or 1 = 1- NO visibility Lock when leaving car; 0 - visibility Lock when leaving car
b4 - 0 or 1 = 1-Visibility Unlock mode
b2 - 0 or 1 = 1-Visibility Unlock mode
Study RBCM:
7B7-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = 0 - no auto door lock or 1 - auto door lock (activates door lock function in RBCM)
b4 - 0 or 1 = function is not known
b3 - 0 or 1 = 0 - 1x blinker when doors close from remote control or 1 - no blinker when doors close from remote control
b1 - 0 or 1 = 0 - no blinker when doors open from remote control or 1 - 3x blinker when doors open from remote control (w/alarm system)
B4 - it is (in BIN):
b6 - 0 or 1 = 0 - OFF 1 - ON (ability to lock doors when Ignition ON) tested on CX5
b3 - 0 or 1 = 0 - OFF 1 - ON (ability to lock doors when doors open) tested on CX5
b1 - 0 or 1 = 0 - if engine work then not possible open boot or 1 - if engine work then possible to open boot (from button on boot)
7B7-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = no data on use
b6 - 0 or 1 = 0 - OFF Find My Car or 1 - ON Find My Car (Press lock button twice on remote controller, You will hear a shortly horn) tested on CX5
b5 - 0 or 1 = 0 - It does not allow to open the trunk in the Drive mode (D) or 1 - It allows you to open the trunk in the Drive mode (D) tested on CX5
b4 - 0 or 1 = no data on use
b3 - 0 or 1 = no data on use
b2 - 0 or 1 = no data on use
b1 - 0 or 1 = no data on use
b0 - 0 or 1 = no data on use
b6 - 0 or 1 = no data on use
b5 - 0 or 1 = 0 - no auto door lock or 1 - auto door lock (only for visible this function on CMU)
b3 - 0 or 1 = 0 - auto door lock or 1 - no auto door lock (only for visible this function on CMU)
7B7-01-03 B0 B1 B2 B3 B4(checksum) in HEX
b5 - 0 or 1 = Lighting Coming Home Light - ON
b4 - 0 or 1 = Lighting Coming Home Light - OFF
Study IC:
720-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B2 - it is (in BIN):
b6 - 0 or 1 = 0 - OFF Beeper driver seat belt; 1 - ON Beeper driver seat belt
b5 - 0 or 1 = 0 - OFF Beeper passenger seat belt; 1 - ON Beeper passenger seat belt
b4 - 0 or 1 = 0 - disable I-Stop; 1 - enable I-Stop (enable/disable button I-Stop and view logo "I-Stop" on Instrument Cluster)
720-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = 0 - Digital display Cruise control on IC; 1 - NO digital display Cruise control on IC
720-04-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B0:B1 - it is checksum for full configuration of car (IC)
720-04-14 B0 B1 B2 B3 B4 B5(checksum) in HEX
b5 - 0 or 1 = 1 - W ALS (Headlight Auto Leveling System); 0 - W/O ALS
b4 - 0 or 1 = 1 - and if b5 = 0, then AFS and ALS (Adaptive Front Lighting system) is OFF, if b5 = 1, then AFS and ALS is ON; 0 - and if b5 = 1 then only ALS is ON
720-04-23 B0 B1 B2 B3 B4 B5(checksum) in HEX
b6 - 0 or 1 = 1 - Cruise Control with LIM
b5 - 0 or 1 = 1 - Standard Cruise Control/MRCC
b4 - 0 or 1 = 1 - W/O Cruise Control/MRCC
720-04-24 B0 B1 B2 B3 B4 B5(checksum) in HEX
b5 - 0 or 1 = 1 - SCBS ON; 0 - SCBS OFF
b4 - 0 or 1 = 1 - SCBS OFF; 0 - SCBS ON
720-04-27 B0 B1 B2 B3 B4 B5(checksum) in HEX
b3 - 0 or 1 = 1 - REAR CAMERA with DYNAMIC ASSIST LINES (7 wires) ; 0 - REAR CAMERA with FIXED ASSIST LINES (4 wires)
for example:
edit string in configuration
7B7-01-03 0018 5400 2E
on
7B7-01-03 0018 9000 6A
adds features:
- RAIN SENSING WIPER
- AUTO HEADLIGHT ON
String 7B7-02-01 no need to change. This string enables/disables activated features, it can be done in media settings.
Connect to study.
Banned
The thing is your images can only be seen when logged in to this forum. If you logout from the forum you can't see the pictures too. That's why nobody can see them.
Thanks for the info BTW. Is there anything different between japan built mazda3 and mexico built mazda 3 my vin number is 3MZBM64A81Mxxxxxx. As I looked in your cruise control topic. You said something about VIN.
Banned
Discussion Starter · #9 ·
Users from Russia, Germany, Vietnam, Japan, Thailand, China, Latin America, Canada, US, UK without any problems activated cruise control.
I've just tried to connect RBCM but I can't see this module in module list. Here is the list of modules i can see with for scan:
Do you have any idea why i can't see the RBCM module.
Banned
Discussion Starter · #11 ·
It is available via MS CAN
You must use a ELM327 with switch HS CAN or MS CAN
How to modified ELM327:
here
and
here
Hi Withe. I've managed to modify RBCM but the problem is my HEX values before auto lock is different than yours. When i put your values. Auto door locking works but my Radar cruise control and smart city brake support not working. Icons are flashing on dashboard. I've restored the original values. I think that's because you don't have such features on your car. Do you know exactly which part of the hex should i change for just door lock. Here is my factory as built RBCM values:
Banned
Discussion Starter · #14 · (Edited)
For example, you have:
7B7-01-01 4550 0005 A1FB
7B7-01-02 A50C 4300 08BD
Where:
50 and 08 - OFF Auto door lock
FB and BD - checksum of your string
Your New DATA for Auto Door Lock:
7B7-01-01 45D0 0005 A17B
7B7-01-02 A50C 4300 20D5
WHATEVER YOU DO, YOU DO SO AT YOUR OWN RISK!
My Car Mazda 3 Allnew 2015 already has this option!
Is there any way edit RBCM to make option: When press lock the car, mirror auto folding without plug any device to car (like auto folding mirror device....)..
Banned
Discussion Starter · #18 · (Edited)
Do you can give VIN of your car for a detailed study of functions door lock
and
Do your CAR has function: LOCK WHEN DRIVING, UNLOCK IN PARK?
Because of:
1st row Checksum = 07+B7+01+01+45+50+00+05+A1 = (1)FB
2nd row checksum = 07+B7+01+02+A5+0C+43+00+08= (1)BD
However I believe Forscan should do checksumming automatically.
My entries are slightly different as well:
7B7-01-01 5D52 0006 E156
7B7-01-02 A51A 4360 082B
So does it mean that this time 52 and 08 is autodoor lock - off?
Banned
Discussion Starter · #20 · (Edited)
Because of:
20 - it is activates selection automatic door lock in RBCM for CMU (only for visible this function on CMU)
D0 - it is activates door lock function in RBCM
Yes:
1st row Checksum = 07+B7+01+01+45+D0+00+05+A1 = 27B and shift left by 8 bits (removed first character) = 7B
2nd row checksum = 07+B7+01+02+A5+0C+43+00+20= 1D5 and shift left by 8 bits (removed first character) = D5
