601 - 620 of 938 Posts
Hello
Did someone manage to get into the Connect 2 system like the friends on Connect 1 and AIO-Tweaks did.
This would allow with some linux knowledge (if Connect 2 is also under linux) to create customization scripts.
Hello
I am experimenting with my CX30's navigation program regarding updating speed cameras and danger zones.
  • It is better to use an SD Clone of the original SD.
  • Delete the old Speedcam.txt and Speedcam.spdb files (if they exist) from the / content / speedcam folder.
  • Retrieve from the Internet an up-to-date database of speed cameras and danger zones in his country.
The .txt format is required
The 1st line of the file must be: X, Y, TYPE, SPEED, DIRTYPE, DIRECTION
(X = Latitude and Y = Longitude)
The following lines must contain the updated data in the format of the 1st line
  • The data file must be named Speedcam.txt
  • Copy Speedcam.txt to the Clone SD card in the / content / speedcam folder.
  • Insert the SD Clone in the car's SD reader and switch on the ignition (or ACC).
  • Start Navigation
  • The software creates a Speedcam.spdb file on the SD and starts Navigation
  • Do not delete Speedcam.txt and Speedcam.spdb files from SD
I am trying to check whether or not to delete the .spc file (from its country) when updating after adding Speedcam.txt.
I think not, but I still check with 2 SD Clones. One with France.spc and the other without.
I note that in France the radars are not displayed (It is the law) but are replaced by a dander zone when one goes in the zone.
Note: The display does not always work when you move the map with the joystick without being physically at the location of the radar.
I'm afraid that by leaving the .spc files (from its country) and the Speedcam.txt and Speedcam.spdb files that duplicates or bugs will appear if the geographic coordinates in the .spc are close but not identical.
Anyway, with or without the .spc file radars (or danger zones in France) are displayed if Speedcam.txt and Speedcam.spdb are present on the SD.
@Goosoom
Hello
Thank you but it is the name of the .kwi file that I want to know, the version you have already announced.
The name of the file will tell me if this file is compatible with my car because apparently I will be very late with my 10049.
@Goosoom
Hello
Sorry but o don't know where i can find the version file.
I only know that in italy mazda update to a new version number 11040
Hi
EU02 versions are for Mazda MX-30 only.Example 7000C0A-EU02_11020
For Mazda 3 and CX30 you have to EU01.Example 7000C0A-EU01_10049.kwi.
Here in Spain there is CX30 new 186 HP e-skyactiveX with version 10051 the first
and last comes with version 11000. but everything with EU01.
This link that is in Japanese explains it
Hi
View attachment 284687 View attachment 284689
Ok...not only sky
Hi
Thanks for the explains.
So my 11000 for cx30 italy version is the last one
Hi,
I've seen the table too but if I understand it correctly it no refers to updates specific for CX-5 that need the EU03 version. I have some discussione with italian and german people and they confirm me that they have the 10022 version too.
You have insufficient privileges to reply here.
