New Mazda Connect Firmware update for CX-5 and CX-9 with 10.3 Inch screen for North American market ONLY.
See Changelog Below..
CMU_7000C0A-NA03_11048.kwi * CX-5 + CX-9 2021 on with 10.3 inch center display.
Changelog
Some vehicles may experience the symptoms mentioned below,
which can be fixed with the latest software update (Version 7000C0A-NA03_11048 or later).
(Ver. 7000C0A-NA03_11048) fixes these software errors (bugs):
• The screen does not show a proper picture when receiving SiriusXM data.
(Ver. 7000C0A-NA03_11046) fixes these software errors (bugs):
• The vehicle icon rotates when using the navigation with head-up mode.
• The system reboots when operating the audio source screen.
• If another incoming call comes in immediately after the hands-free call is ended, it is automatically accepted.
• Audio tracks stop playing or are muted when playing them using the Apple CarPlayTM.
• The system may reboot.
• A beep sounds after every couple of minutes.
• Language setting may not be accepted correctly.
• The screen shows “Phone in use” message and it stops playing audio tracks while playing audio tracks
using CarPlayTM and refusing the incoming call.
• The audio track may not pause when pressing the mute button.
• The screen freezes when smartphone receives messages under Bluetooth® connection.
• The system does not resume a play list after editing it for an USB audio device.
Ver. 7000C0A-NA03_11040 fixes these software errors (bugs):
Ver. 7000C0A-NA03_1138 fixes these software errors (bugs):
• DTC U3000:49 is stored which may be accompanied with following symptoms.
- No sound comes out from the speakers.
- Audio source selection is unavailable.
- The system reboots.
Ver. 7000C0A-NA03_11032 fixes these software errors (bugs):
• Update detail screen shows incomplete sentence and trying to scroll to the
beginning of the sentence leads to the whole sentence disappearing.
• Turning the main power off may lead to a reboot while playing audio tracks
using Android AutoTM and displaying the map using Android AutoTM.
• Voice command may not be recognized.
• Turning the main power on may lead to a reboot after connecting a device to use Apple CarPlayTM.
• Android AutoTM may fail to connect.
• The 360° view monitor screen may be overlaid with the home screen.
• DTC for disconnection of the mic may be stored in the CMU after updating the
emergency call unit (TCU in MDARS) software.
• If the volume knob is pressed and held to turn the power off while adjusting Fader/Balance,
the lines showing current setting for Fader/Balance may not appear the next time the power is turned on.
• Turning the main power off may cause the display to keep turning on while using Android AutoTM.
• The parking sensor screen may freeze after particular operations.
• Track selection using voice command may result in the error message “Too many tracks.
This function is not available”.
• After selecting certain speed for the speed alarm, re-opening the screen shows default setting
instead of the selected one while multiple USB devices are connected.
• The device name may not appear when connected using CarPlayTM.
• DTC U2301:56 may be stored after installing an accessory device.
• Album artwork may not appear when playing music using a USB connected iPhone.
• Android AutoTM may not appear on the entertainment screen.
• The screen may turn black when using CarPlayTM.
• The screen may freeze when a Bluetooth® device is disconnected.
• The destination may not be registered when a destination is sent via MyMazda application.
• When it reboots, registered information for a paired Bluetooth® device may be lost.
• The center display may turn black when the gear is shifted from reverse position to park position.
• Steering switch operation for auto-tuning may erase the banner when listening to the radio.
• Screen freezes and goes to white screen, then the system reboots.
• The audio selection switch does not work.
• It takes time to establish Bluetooth® connection.
• Mobile911 function may not place a call while no Bluetooth® device is connected.
• Mobile911 function may not place a call when using CarPlayTM.
Ver. 7000C0A-NA03_11026 fixes these software errors (bugs):
• The system may reboot repeatedly right after starting the vehicle, and removing the navigation
SD card stops the rebooting.
Ver. 7000C0A-NA03_11024 fixes these software errors (bugs):
• Place markers setting may not keep the change and it may return to the default setting.
Customers having this concern should have their vehicle repaired using the following repair procedure.
