1,001 - 1,020 of 7,282 Posts
klyue2003
I think I know how to activate the leaving home light.
Today I've found out my CX-5 has leaving home light and coming home light by default :smile2:
There are corresponding settings in CMU.
So, here is my R_BCM as-built:
7B7-01-03 0038 9210 9C
It means to activate leaving home light and coming home light you need to set bit b4 and b5 in byte B1 of 7B7-01-03 configuration string.
Code:
7B7-01-03 B0 B1 B2 B3 B4(checksum) in HEX
B1 - it is (in BIN):
b7 - 0 or 1 = function is not known
b6 - 0 or 1 = function is not known
b5 - 0 or 1 = Coming Home Light - ON / Leaving Home light
b4 - 0 or 1 = Coming Home Light - OFF/ Leaving Home light
b3 - 0 or 1 = function is not known
b2 - 0 or 1 = function is not known
b1 - 0 or 1 = function is not known
b0 - 0 or 1 = function is not known
I guess the possible configurations are:
7B7-01-03 001x xxxx xx - Coming Home Light - DISABLED
7B7-01-03 002x xxxx xx - Coming Home Light - ENABLED
7B7-01-03 003x xxxx xx - Coming Home Light and Leaving Home light - ENABLED
klyue2003
Code:
Your car is a CX-5?
If yes, coming and leaving home is activate bu default but run its a little special.
To activate coming you have to pull high beam switch to steering wheel.
And leaving home only run if low beam switch is in low beam position (not in Auto one)
Enviado desde mi iPhone utilizando Tapatalk
Your car is a CX-5?
Yes, my car is Mazda CX-5 2016.
(https://www.drive2.com/r/mazda/462149477239620912/)
You are absolutely right! I checked these functions this morning.
And it works as you described.
klyue2003
Code:
So this can work for 2015 Mazda3 ? :>
klyue2003
Code:
7B7-01-03 XX2X-XXXX-XX ON 2014 discharge(HID) headlamp , It becomes headlight off delay 30 sec. But on 2015 with LED headlamp , It not working .
Hi, could you help me with my mazda 2 2015 i would like activate door lock and leaving and coming home lights
my car has iactivsense,pack safety called in spain with hbc.
thanks and excuse my poor english
hi @ambizurdo
My Car is Mazda 2 -2016
It has auto door lock and coming home light.
Please check module 726-01-01 to compare and try to change to active auto door lock and Coming home light
hi @ambizurdo
Thanks a lot! This asbuilt data is just I need to try to enable autodoorlock on my wife's 2016 Mazda 2.
Muy BCMM has already coming and leaving home lights enabled.
Enviado desde mi G620S-L01 mediante Tapatalk
Yup. Mine is 2015 with LED headlamp, both configuration below not working.
7B7-01-03 XX3X-XXXX-XX
Mine doesn't work too. Mazda 3 2014 HID headlights. Only home coming is working. Just for info.
