1,021 - 1,040 of 7,282 Posts
Currently I'm investigating on Mazda 2/CX3 BCM ASBuilt. I need more AsBuilt data from FORScan to build the template with all options.
I'm pretty sure wich bits are related to autodoorlock and other options.
Thanks to all!
Door lock in Mazda 2 control by Module 726 and it not display in asbuilt.
so you just use Forscan to read inside your car only.
I tried this configuration for auto locks door for my 2015 CX5, It it working but it never appear Locks door mode option on CMU. So when driving it will lock and unlock when ignition off.
to make it appear on your screen settings,go into vehicle settings choose door lock and reset that screen. your new door lock options should appear on that screen.it worked on my mazda 3.
Hello, everyone!
I found the region code and Rear seatbelt indicator, Speed Alarm function.
Tested by the ATENZA(Mazda6) in Japan.
Study IC:
720-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B0 - it is (in BIN):
b7 - 0 or 1 = 0 - W/O Rear seatbelt indicator; 1 - W Rear seatbelt indicator
b6 - 0 or 1 = function is not known
b5 - 0 or 1 = function is not known
b4 - 0 or 1 = function is not known
b3:b0 - 0 or 1 = region code (Language displayed on IC)
JPN:0000
JMZ(EU):0011
JM1(US):0101
JM0(AU):1000
B2 - it is (in BIN):
b7 - 0 or 1 = function is not known
b6 - 0 or 1 = 0 - OFF Beeper driver seat belt; 1 - ON Beeper driver seat belt
b5 - 0 or 1 = 0 - OFF Beeper passenger seat belt; 1 - ON Beeper passenger seat belt
b4 - 0 or 1 = 0 - disable I-Stop; 1 - enable I-Stop (enable/disable button I-Stop and view logo "I-Stop" on Instrument Cluster)
b3 - 0 or 1 = 0 - disable Speed Alarm; 1 - enable Speed Alarm
b2 - 0 or 1 = function is not known
b1 - 0 or 1 = function is not known
b0 - 0 or 1 = function is not known
Hello, everyone!
Study IC:
JPN:0000
JMZ(EU):0011
JM1(US):0101
JM0(AU):1000
As I know
b3~b1(*) =region code (Language displayed on IC)
b0 - 0 or 1 = 0 - W/O TPMS , 1 - W/I TPMS
b3~b0
JPN
w/o TPMS is 0000
w/i TPMS is 0001
AUS
w/o TPMS is 1000
w/i TPMS is 1001
CHINA
w/o TPMS is 1100
w/i TPMS is 1101
What do you mean by "reset that screen"??? I have similar problem on M3 Sedan.....
gazz01, excellent!!! I followed your steps, it is working now!!
How did you reset screen??
Ok I got it! ? sorry for dumb question but I never used that function! ?
Tell us your VIN , We will try to help !
And if you want to DIY , you will need a modified ELM327 or something can read/write your RBCM !
Hi Lewis-Liu,
sorry for the late reply, i was away for sometime. i have attached the photo of the label beside driver's door. hope it is useful.
I have got a ELM327 with MS_CAN selector switch. i did follow the instruction to change the code for auto_lock, but somehow it seems like switching off some other features....
let me know how i can upload my RBCM data.
Hi Lewis-Liu,
u need to edit the rbcm also.
got two rbcm in the configure to edit.
Hi Lewis-Liu,
For Auto Door Lock
7B7-01-01 09D8-0006-E38A
7B7-01-02 A518-0300-20A1
For M2, CX3 adjust for auto door lock
Module 726-01-01
Auto door lock mode: Off
1012 5809 B2
Out of Park unlock: in Park
5012 5809 E2
Shift out of Park
4012 5809 E2
Lock: When driving unlock : in Park
A012 5809 42
Lock: When driving unlock : ING off
3012 5809 D2
Lock when driving
2012 5809 c2
Module 726-01-01
1012 5809 B2
5012 5809 E2
Shift out of Park
4012 5809 E2
A012 5809 42
3012 5809 D2
Lock when driving
2012 5809 c2
Can you post your IC AsBuilt? Forscan returns "incompatible blocks" when I try to write this values on BCMM. Thanks.
The parameter above I took it from my car(mazda2).
After I changed the value in Mazda Connect, I read the data in IC by Forscan and wrote down.
Please try to change one by one.
IC is another module, 720, not 726 BCMM.
I think BCMM AsBuilt stores only custom settings. Please, read the Instrument Cluster AsBuilt and post it. Thanks.
