61 - 80 of 7,301 Posts
In the US we dont get i-stop, a i-stop disable button, or information on it in the CMU. Is it just a firmware change to enable it?
Hello Withe
I'm wondering how about to active Headlight Off Timer in asbuilt.
Can we active this pernamently?
Because i use ELM327 with modifycation to edit in RBCM directly, everything OK, but when i press write button, it run 99% and show the error can't write because incompatible config.
So i thinking only way to active Headlight Off Timer is modify RBCM in asbuilt format like active cruise control....
Automatic Door Locking Success
Well, that and with locks figured out, need to change the lines in RBCM module:
7B7-01-01
and
7B7-01-02
Data without automatic locking:
Data with automatic locking:
http://www.youtube.com/watch?v=tNpWT2dNEx4
http://www.youtube.com/watch?v=RvSQacJsvTE
Use windows's or mac's built-in calculator in programmer mode.
Thank you very much guys. I managed to activate my automatic door locking.:thumbup 1:
You guys rock.
It'd be amazing if someone can figure out how to make the car not hyper flash when putting in LED turn signal bulbs.
I'm driving a Mazda 6 with Alarm System in Germany and maybe this is interesting:
My original value of the b1-Byte is:
52 = 0b01010010
I tried to activate auto door lock by replacing my b1 Byte this way:
D0 = 0b11010000 -> auto lock is working fine, alarm system not working (no 3x flash when I try to deactivate it via remote control)
D2 = 0b11010010 -> auto lock is working fine, alarm system also working!
So, my thinking is:
7B7-01-01 b0 b1 b2 b3 b4 b5(checksum) in HEX
where b1 - it is (in BIN):
0 or 1 = 0 - no auto door lock or 1 (0x80 in HEX) - auto door lock (activates door lock function in RBCM)
0 or 1 = function is not known
0 or 1 = 0 - blinker when doors close from remote control or 1 (0x08 in HEX) - no blinker when doors close from remote control
0 or 1 = 0 - alarm system disabled or 1 alarm system activated
Confirm. Checked on Mazda 6 GJ FL in Poland
:smile2:
This is impossible with just a setting. There is a logic tracking current through bulbs to signal driver when a bulb is dead (current is less than normal) and turn signal flashes faster. Same happens with LED turn bulbs as they consume much less current than usual bulbs.
Probably there is a workaround with replacing turn relay. This works fine with older cars with less electronic. Or you can add extra ballast resistance in parallel to LED bulb to increase current (this is stupid solution for me though).
Hi Withe
Amazing work with this Thread.
I want to add Auto Door Locking to my Irish Mazda3GT which also has
Rain Sensing Wipers
Hid Headlamps
Keyless Entry with walk away locking and Alarm.
I bought a modified elm327 from ebay, installed Forscan and got it all working ok my problem is that the ASBuild RCBM Data from my is different to yours and although I can see that I should change 52 and 08 I'm not confident that I will get it right so could I please ask you to calculate the new values I should apply.
I have:
7B7-01-01 5D52 0006 E156
7B7-01-02 A51A 4300 08CB
Lots of respect and thanks in advance for your help - Pav
CMU Menu
Vehicle
Rain Sensing Wiper >
Door Lock >
Turn >
Lighting >
Door Lock >
Keyless Lock Vol > med
Auto Relock Time > 30 sec
Walk Away Lock > X
Reset
About Headlight off timer
With a cruise like understood. Has come time for other useful functions.
I ask all who have a desire to connect to study.
Study RBCM
0 or 1 = 0 - 1x blinker when doors close from remote control or 1 (0x08 in HEX) - no blinker when doors close from remote control
0 or 1 = 0 - no blinker when doors open from remote control or 1 (0x02 in HEX) - 3x blinker when doors open from remote control (w/alarm system)
7B7-01-02 b0 b1 b2 b3 b4 b5(checksum) in HEX
where b4 - it is (in BIN):
0 or 1 = no data on use
0 or 1 = 0 - no auto door lock or 1 (0x20 in HEX) - auto door lock (only for visible this function on CMU)
0 or 1 = 0 - auto door lock or 1 (0x08 in HEX) - no auto door lock (only for visible this function on CMU)
for example:
edit string in configuration
7B7-01-03 0018 5400 2E
on
7B7-01-03 0018 9000 6A
adds features:
- RAIN SENSING WIPER
- AUTO HEADLIGHT ON
String 7B7-02-01 no need to change. This string enables/disables activated features, it can be done in media settings.
Connect to study.
Did you know the address of data in asbuilt to enable Headlight Off Timer, and what value to change to active this function?
Thank you!
Discussion starter · #75 · (Edited)
Hello sir! I'm just curious, if the vehicle is equipped with alarm the value to be input is D2 instead of D0? Thanks in advance.
For accurate calculations it is necessary to know exact data of your car!
Hi Withe, do you know which module should we program and which values need to be changed for CX-3?
I have assumptions, but I can't check. Unfortunately in Russia there is not Mazda 2 and Mazda CX3
Thank you!
I have assumptions, but needed check
Hi! Regarding the cx-3, what information is needed to deconstruct the asbuild data andactivate the auto door lock? Ill receive my car soon and would like to add this feature. I have an elm327.
Regards
