I have had a 2015 Hatchback since new and this has been a problem for a couple of years. I read every post, thanks for everyones input. I live on the Sunshine Coast in Australia which has the same climate as Florida. This year has been one of the wettest on record with the La Nina system causing havoc. I decided to go the nuclear option and solder the wires.
If your are unsure of the pairing of the wires, either cut them one at a time or take a photo. None of the colours match up. One pair is dark grey and black so take care.
I took all the panels off in about 10 minutes, the only tricky one was pulling the long centre pin out of the lugs that the shelf cords attach to, then pull out the lug; only because this was new to me. I then cut the plugs off (cut through the plug) about 10mm from the wire so that the wire and crimps came out, giving me maximum wire length, and then cut the little crimps off the end of the cable. I then split the outer jacket with a small pair of sidecutters and pushed it back, stripped about 12mm of insulation and soldered the wires.
Due to the length of the wires I had to twist them like you would poke your fingers into each other and twist, takes a bit of practice but good for tight spots. Solder went on well, taped individually. Used the original jacket and wrapped more tape around to make a neat job. Taped the camera wire to the panel/main loom closer to the camera.
Before I put the panels back on I made sure the plugs lined up and popped them in. The trickiest ones are the side panels. They have 3 "hooks" on the top edge. The one closest to the glass is fiddly. Flex out that edge and locate that hook first, then the rest will follow easily.
I tested it before I put it back together and it worked. I then put it all together and went for a short drive to see what it looked like in daylight, excellent. For it to work 10 times in the matter of minutes is a good sign. For the past couple of years it would be lucky to work once a week, and I make about 4 trips a day.
Thanks again for everyones input.
