So.. getting a little play in the cars steering wheel before the wheels move and some responsiveness issues from the driver side front wheel over bumps and while turning.
I jacked up the car and there was a little play in the wheel when doing the 3:00 and 9:00 push/pull method. I could also twist the outer tie rod by hand a little. No clunking though.
Not sure if the inner tie rod is shot.. needed a 2nd set of hands to check that.
Has anyone replaced their tie rods? If so, what brand did you use for the replacement parts? I see Moog, TRQ, Detroit Axle, and stock Mazda, obviously, as potential replacement brands from a quick search.
Also, did you replace both the inner and outer tie rods or just the outer?
Going to drop it off next week to get the inner tie rods checked so, I can get this fixed in one go. TIA!
