6,441 - 6,460 of 6,600 Posts
Is there any App or tweak in AIO that will show some more info from OBD2 ?
I'm asking if there is any way to display things such: Battery voltage (not Bat SOC), Oil Presure, Oil Temp, Fuel Temp (as there is a temp sensor in the car), DPF regen cycle... etc.
I'm asking because those options are available via OBD2 and I think there is a way already to read ECU/OBD2 via infotainment system.
Thanks
Thanks
This may be completely unrealistic given the limitations of the system but I like the concept! I have actually seen something similar on an older vehicle. I suppose that the data is readily available...the trick would be however, if it could be displayed in some way. Nice post @Yonef!
One other question:
My speedometer app does not show intake temp. (actually it shows "---")
My mazda 3 is Diesel Skyactiv-d 2015 2.2 150 HP - does this means that this model does not have a intake temperature sensor, or the sensor is broken?
Thanks
1. You want to do a firmware (FW) update?
2. Is the USB stick formatted FAT32 at a windows system? It should.
3. Which FW version exactly is currently at the MZD installed?
4. Which FW version exactly do you want to install?
5. Have you checked the hash sums of the file at the usb stick with the hash sums it should have? See hidrive server for the hash sums.
6. Is the usb stick recognized at all, when plugged into the car? Means showing up in top row for a short moment? Otherwise see bullet 2 or use another usb stick, as some are not recognized by the MZD.
If you use a region version which is not for your region, some things might not work. I would not recommend it.
And there is no FW 59.00.564 - for no region - just as info. And .546 NA I would not recommend, as there was deleted a setting for the rear camera due to legal reasons only - so .545 NA was better - from users perspective.
I only have a black screen but the radio plays.
With Google Translate from German Forum:
In the hood lock is a small switch, which mediates whether the hood is open for maintenance purposes.The i-stop is disabled for maintenance purposes. The switch is fixed with a screw and has a plastic pin that sits in a bore. Loosen the screw, turn the switch so that the pin sits next to the hole and screw on again. Now it is no longer pressed with the hood closed and the i-stop is permanently deactivated!
Since we have no control light for the bonnet, there is also no error message!
Hello, I've seen this 'fix' before and I'm keen to implement it to save my sanity!
Would it be possible to provide information on how to get access to the hood lock and small switch.
I have plastic trim (cover) (over the space between the grille and radiator where the hood lock and small switch are located) that appear to be held in place by fasteners that are round black plastic with a smaller round piece in the middle (they look like a bulls eye). How do you open / release them?
Thanks for your help!
To get to know your current MZD firmware (FW) version go to MZD settings -> tab system -> about -> version (or something alike).
If the current software version is older than 55.00.650, update first to 70.00.100 (Downloadlink), then update to the latest version 70.00.352 (Downloadlink). If the current version is 55.00.650 or higher, you can update directly to 70.00.352.
Here you can download the latest FW for North America region (70.00.352 NA) and a PDF with the installation instruction. Stick to the word to it and read it before starting the update. All on your own risk. You could brick your CMU (new approx. 1000 USD). Mazda does not intend users to do FW updates. The PDF shows the instructions for their dealers. Good luck & fingers crossed, that your issues will be solved with the new FW :)
Hi Tristan,
Thanks for your reply.
But i was not able to find settings option in the system. I have attached picture of the system i have in my car. can you please check if you have any instructions about this one.
Thanks alot again.
Shivam
275887
I took the first step and installed AIO. I have a few issues that I'm trying to resolve but I would like to just ask about one.
Ever since the installation, the entire infotainment system seems really dull witted. Everything is much slower to load as well as to respond to user inputs.
Any ideas? I did not change the firmware version or upgraded Gracenote. I would like to avoid adding more variables until I can address the current issues.
Thank you!
