Scary Transmission Color
1 reading
9.9K views 7 replies 4 participants last post by  zero_gravity
#1 ·
Hey everybody. I MIGHT have a bit of an issue here. I checked my automatic transmission fluid in my 2014 Mazda3 2.0L today and came across something that made me a bit uneasy. The color on the dipstick was a light-brown or mustard-brown color. I'm not sure why it's not the typical pink color I see on most cars. This car has 40,800 miles on it currently and 31,000 of those are from me driving. I never drive it hard (as I rarely get it above 3k RPM's) and I'm pretty meticulous when it comes to routine car maintenance. I would like input from fellow forum members about why this might be the color it is. It would be greatly appreciated if you could post some pictures like the ones I have attached below of your own cars along with the mileage you are sitting at if you haven't changed your factory fluid yet. Thanks! Please ignore the level of the fluid on the dipstick as I did NOT warm up the car to the correct temperature and it was sitting all night. I was interested solely in the color so the level is most likely not accurate.
#2 ·
#3 ·
With 40,000 miles and a 120,000 mile warranty would it just be better to go to the dealership? The problem here is that I don't know what the "stock" color of this specific fluid is as I know that transmission fluid color can vary depending on what manufacturer it is.
#5 ·
Does your warraty specifically cover the running gear?
It will not hurt to have the fluid tested. Dealership generally do not get fluids analyzed. Most I would assume never knew you could. :smile2:
You will not void the warranty should you decide to have the transmission serviced from a ASE Service shop. Just keep your records.
#4 ·
In the mean time should you take my advise....in my first response?
I would change the fluid pan and filter service . Examine the fluid the comes out for any thing other then ATF.
You can also take filter apart on automatic transmission and see what it filtered since the last filter change.
#8 ·
It's likely fine, but it doesn't hurt to have the dealer check it out. That's what a warranty is for after all.
Transmission fluid isn't naturally red...it's dyed red. They do this so it doesn't get confused with engine oil. Over time and use, the dye will come out but that doesn't mean that the oil is done or something else is wrong.
Your dye didn't last long....I'd get it checked regardless, but I'm guessing just fine.
