Is it important to change the smaller rubber boots on front caliper guide pins?
8.8K views 9 replies 4 participants last post by  mozley
#1 ·
Hi! So I have a 2014 Mazda 3 (Japanese), and I've been trying to do a DIY brake + rotor change on all 4 wheels.
While doing the fronts, I noticed that the lower caliper guide pin has a rubber bushing that's nearly flush with the pin, in addition to the bigger one that's outside. I have replacements for those in the boot kit I bought.
It seemed pretty flush and tight, and I was worried that I'd have to cut it out and might have an equally hard time getting the new ones in.
1. Is it important to change that bushing? I guess you might have to cut out the older one, but the newer one wouldn't be that hard to slide on with some lube.
2. My lower pin also seemed to have a harder time moving in and out, even after I cleaned and lubed it. I thought that it was because of that bushing - it sticks out and makes the lower pin harder to move, by design, for some reason. Is that okay, or does that indicate that that older bushing is going bad or something?
Thank you!
#3 ·
Thanks. So I had a hard time looking up Mazda-specific info for that thing, but on some other brand forums it was suggested that the older ones can swell up and make the pin hard to move. Since my lower pin is hard to move even after lubing, is that a good reason to try grappling with it?
#7 ·
worth mentioning is to give those boots a good inspection. if they're swelling or split anywhere they should be replaced. like when a CV boot is damaged, grease comes out and dirt gets in. slide pins will eventually seize. if there's nothing wrong with them keep the new boots in a safe spot for the future. nice to have on hand if you notice a damaged boot one day.
#8 ·
One slide pin was very bound up on my daughter's Mazda 3 and after pulling the boot I found brake dust caked all around it. The boot looked sealed and wasn't torn...can't even guess how all of that got in there. Cleaned all of that out with a brass bristle and a nylon bore brush and pulled a new boot through.
