So I have been running my camera for about 18 months connected to an internal fuse and it has been working fine, shutting down as expected. After seeing all these posts I thought I would do some testing and I think I have a 100% working solution for those that want to utilise the internal fuses which we all know are not switched and are all constant.
So the solution to this and the issue with constant fused power is to make sure you purchase a dashcam with Parking mode, or enable it on your current camera. What Parking mode does is it shuts down the camera when stationary, normally this time is around 5 minutes but can be longer depending on model. Then if for what ever reason the system detects movement, using the G-Sensor the camera will turn back and and begin recording, again this starts the timer off again before shutting down. Most dashcams facilitate this function by utilising an internal camera battery which is often a very small rated mwh, the constant fuse will actually charge the camera a little during this 5 minute on time.
Sadly if you camera doesn't have a Parking mode (other than its cheap and needs binning), your only option is to hardware to the fuse under the bonnet (or buy a new camera
p.s if you don't use Parking Mode, your camera will record 24/7 and your car battery may go flat in less than 48 hours. If this does happen, you may have to call breakdown, as the Mazdas hate a flat battery, even if you charge it up the car may not start and if you do get it started you may have loads of error codes to clear (essentially every system fails and generates and error code).
p.p.s some dashcams allow you to plug power directly into the camera itself, or a GPS receiver, make sure you plug into the receiver and not the camera as this can affect packing mode.
