21 - 40 of 59 Posts
I've painted wheels using the duplicolor cans before and what can help/speed up the process is to use aircraft paint stripper instead of sanding it. That takes off the pair and clear coat from the rims just fine.
Discussion starter · #22 ·
I actually tried that on these rims and it was a disaster. Basically, it's great if the rims are a smooth cast, but ours aren't. It's actually pretty rough underneath the powdercoating. Also, it doesn't come off very easily. I was using strong aircraft-grade paint stripper too (strong enough it burns the skin within 5-10 seconds). After I was done, I was left with some rough wheels that required a lot of primer and sanding to even be ready for paint. You all are welcome to try it, but don't say I didn't warn you. Lol.
LOL yea I used like the HEAVY duty stuff and it burned my skin fairly easily. I used it on a set of 5zigen Heidfelds and the paint came off pretty quick. I just wanted to throw that suggestion out in case someone didn't want to go through the sanding process but it seems like with the stock wheels you might have to put in the elbow grease.
Discussion starter · #24 ·
Yeah, aftermarket wheels are usually a much smoother cast and easier to strip. It's work either way and I don't think sanding is that bad. Maybe I'm just used to it. This was my 9th wheel to paint, heh.
Nice write up derrick! Im going to try this on my isport but the rim is plastic and i can just rip it off my wheel. You think the paint will stick to the plastic?
Discussion starter · #26 ·
It should stick. It may not be as durable as painted alloys though. I'm not sure.
i was really dissappointed that it wasnt even alloy. I started feeling my rims after you posted this thread, and i ended ripping it off,haha I'm surprised the rims dont fail out when i drive
Discussion starter · #30 ·
Derrick,
After your last paint coat do you sand before the clear coat? And, after your last clear coat do you sand it or just let it dry?
Good questions. I definately sand the last coat of base, usually with 1000. I typically sand between clear coats with 1000, then 2000. The last coat of clear is a light one and I don't sand. This is done so I don't have to use rubbing compound and buff them. It's good enough for me, but there is always that extra step you can take to make things better.
Umm...you just linked back to this thread. I'm sure it's a mistake, but I Lol'd.
lol yup... but you did explain in the begining about sanding down the primer and coats in the write up :blink 1:
Yeah I laughed too. I was like that didn't answer my question.
Ok so to break it down:
sand, prime, sand, prime, sand, prime, sand
paint, sand, paint, sand, paint, sand
clear coat, sand, clear coat, sand, clear coat, done
Is this correct?
Step 8: Sand the base color and re-coat
You should be a pro at sanding by now. Depending on how rough your first coat is, wet sand with 800 or 1000. It's okay if the paint gets thin in areas, but you shouldn't sand through to primer. Rinse and dry thoroughly. Repeat this as necessary until the paint if opaque and smooth.
Step 9: Spray clear, sand, and re-coat
Using the established process, spray clear coat, sand, and repeat. I generally spray 3 coats. For the first 2 coats, I sand with 1000. For the final, I sand with 1000, followed by 2000. Once you're satisfied, remove all masking and leave to dry overnight (minimum).
it did answer your question.... that's why i linked you back to the write up
OOOOHHH!!!!BURN sorry, just had to say that... lol, it makes you feel better...
haha well unless I'm reading it wrong it wasn't clear in the original post. In the original instructions he says he sands his final coat. But in his reply to me he says he doesn't sand the final coat.
Basically to rehash. Is the last coat of color sanded or just painted? And, is the last coat of clear coat sanded or not?
He answered you on the last page... I'm just sayin... :stuart:
Reactions: JayEdge25
so for the center caps I have to do the same process of painting a wheel?
So how do I paint the stock wheels again? lol
Great writeup!
21 - 40 of 59 Posts
