4,341 - 4,360 of 7,288 Posts
I need some tips/advice... I've 2015 CX-5 with all the features displayed on the photos...
Can anybody recommend anything useful I could do with forscan? I plan to "stop i-stop" ;) and I was hoping I could do door auto lock (I don't seem to have the button on the door panel - only have windows lock button and the "knob" to manually lock - so not sure if it can be done).
Any other interesting/useful things I can do...?
And BTW - what is "Auto headlight on" "medium"..?
Hello
To know what you can do you will need the list of modules installed (with forscan)
For the Auto Door Lock you do not need the button on the driver's door and the coding will work on your CX5
For "Auto headlight on" "medium" it is the brightness of automatic lighting start
OK, thanks...
I attach screenshot with the list of modules.
Also attached output from IC module... I'm not sure how to read it but does it mean I have adaptive lightning system? Or BSM (which I don't think I have...)? Or LDWS (which again - I don't think I have)?
And rbcm - I'm assumign "Not adopted" means something I can set (eg. auto door lock or headlight off timer - which I don't even know what it is...)...
Any other cool things I can do with these modules...?
OK, thanks...
Hello
Look at the "i-Activsense" tab of the excel file
You will see what modules are needed to run an option
You do not have the FSC module so no LDWS
You do not have the RVM module so no BSM
You do not have the AFS module so no ALH
You have RBCM and you can code ADL
You have SSU and you can code i-STOP
For i-STOP you must have an ON / OFF button on the left side of the dashboard.
Forscan coding of i-STOP to OFF will permanently set i-STOP to OFF (until next coding).
Be careful and always make a backup of the module to code before coding.
Nota: It's not forbidden to click on "Thanks" when someone answers a question on the forum!
Has auto headlights been figured out yet? Can a dealer do it?
Hello
if you have the brightness sensor on the windshield it should be possible otherwise you have to install a windshield with a brightness sensor
Note: It's not forbidden to click on Thanks when someone answers a question on the forum !
Hello
Yea my 2017 has the sensors but has anyone figured all the coding?
@rixm6
Do you have the angel eye around your headlight turn on with DRLs or only with parking lights on your mz6?
Would you mind posting your FBCM asbuilt?
Thanks!
DRL and parking lights
;Block 1
7260101FA66092ED89E
726010266AAD35656BF
7260103525AAAA62D
;Block 2
72602017FAF
;Block 3
72603017FB0
;Block 4
7260401083A
;Block 5
72605010033
Hi, Thx for the Link, but i mean the Application for the AS Built not the xls
for example AS Built Editior v1.1
There's no app afaik. Did you mean ForScan? its not an editor, but just the app used to upload changes to the car
@rixm6
Thanks!
;Block 1
7260101FA66092ED89E
726010266AAD35656BF
7260103525AAAA62D
;Block 2
72602017FAF
;Block 3
72603017FB0
;Block 4
7260401083A
;Block 5
72605010033
Thank you!
