I installed the JBR rear adjustable camber arms and Megan Racing adjustable toe arms over the weekend.
I ran into many stubborn bolts and I wasted many hours working on bolts that would just not move...even with Liquid Wrench applied.
I had my car in yesterday for its regular maintenance check (I'm still under warranty somehow), and asked my mechanic, Freddie, about it. He said when working on suspension components, you really need a 6 pt impact socket to generate enough torque to get them moving. It will also prevent rounding of the bolt corners, which a standard 12 pt socket will do.
So, in short, if planning any suspension work, save yourself some headaches and get a 6 pt impact socket set. 14mm, 15mm, 17mm and 19mm are popular sizes. Also, I'd get a deep socket set, a standard socket set and some extensions. Not being able to properly fit or reach a bolt in a tight spot can literally make or break a job.
I've also learned having the keys to a second car can save your bacon when you need a tool in a pinch.. or an energy drink.. or a beer.. you already have the concrete walls to bang your head against when things go wrong at least..
Any other tips for essential equipment needed for these jobs? Liquid Wrench is another essential in the tool box, as is a 24" breaker bar and a 3 ft pipe (part of my hydraulic jack) too.
