here is the procedure if you dont want to take it to the dealer or if your dealer cant find the TSB
mine is minimal now but still annoys me here and there. I'm going to look at it tomorrow and hope i don't break anything. thanks alot...Good news peopleI think I figured out exactly which area the tick noise comes from.. I can't say with 100% certainty its the same for everyone with the tick, but it may help the majority of the people.
On the TSB it specifies two places to make a gap, E and F, E is a little lower on the bracket and F is a little further up where it touches the dash upper panel. I took a picture after I put everything back together unfortunately but I circled where the part is where the gap needs to be made, its under the black wiper cowl. The circle in red, labeled F on the TSB was the culprit!
The dealer made the gap at the point labeled E in the TSB (Green circle in my picture). They made a pretty big gap there, at least a few mm, definitely more then the .5mm stated in the TSB, they also didn't use any tape apparently when making that gap and used what seemed to be a jack hammer at that point, scratches all over the place.. I did the best job I could with touchup paint to cover up there scratches thereAnyways, this obviously had no effect on the tick noise for me.. I would say don't bother with making a gap here and just make it at the point labeled F on the TSB, or where I circled red.
Just so you know, the dealer didn't even bother making a gap anywhere but point E (green). They didn't read the whole TSB apparently. Chances are many of you have the same issue, where the dealer only made one gap. I did it myself though, removed the wipers, the plastic wiper cowl (just 5 plastic pull clips), then made the small gap about 1mm big. Super easy to do, will take you maybe 20 minutes. This solved my issue. I only went on a short test drive, but the same drive before making this change would have caused many ticks, so I think its all good now
I hope this helps some/most of you. Let me know if you have any questions. Lesson learned, if I have any work done at the dealer again I will insist on watching the entire time, I know not all mechanics are idiots.. but apparently the one I had was and I won't trust this dealer again!
Well. They re-did the TSB today as per Mazda is what I was told. They road tested it and said it was fixed. Last time it was fixed for a few days and the tick came back. So the car is home and I will advise what happens.
It could be weather related, possibly if its hotter or colder, as metal expands, even just a very minute amount. I would just suggest making the gap a little bigger, maybe spray some lube or grease in there. I don't think you will break anything thoughmine is minimal now but still annoys me here and there. I'm going to look at it tomorrow and hope i don't break anything. thanks alot...
i brought it to a dealership but was unable to re create the faint noise (after 4/5 fixes). i do hear it but it comes so randomly now. i drove over a patch of road which made the noise as i drove to the dealership and then i drove over the same patch with the technician with me and no noise...uggg.
one day it is less frequent...the next day it is more frequent. i wonder if it's the weather...hot or cold.
I appreciate all the help you have provided.
Yeah, the black plastic cowl is pretty easy to move, just those 5 plastic clips and then pull forward. It said in the TSB to disconnect the wiper fluid hose, but there is enough slack to move it at least 8-12 inches which is more then enough room.Did it myself. Didn't even have to fully remove the cowl. Just took out the 5 clips which made enough room to push it out of the way so I could hammer the metal just enough to create a gap. Put a couple of squirts of lithium grease in the area just for the heck of it before replacing the cowl clips. Thx!!!
Just had the revised TSB done today at the dealership(build date May 2014), noise is still there. They contacted Mazda to see what to do next... My car has 200 miles on it , and the noise was present 2 days after I picked up the car....
I mentioned this once before, but you'd be wise to inform Mazda of your findings. They would likely have their engineers repeat your fix and test for verification. If they concur with your results, then an official TSB would be posted. This would benefit all the Mazda customers seeking a resolution to this, and maybe even get you something of value from Mazda. Thanks again for posting your fix.I've had the dealer perform the tsb a few times, and the last one made it worse. I ended up fixing it myself.
http://mazda3revolution.com/forums/...-discussion/68273-i-might-have-solved-dreaded-passenger-dash-ticking-sound.html
Been almost a month since I did the fix and the noise never came back.
Yeah I might go stop by the dealer this weekend and see what they think. I was going to show this to them when I go in for my next oil change since they're not exactly close by lol I'm very curious to see if this will help others as well so I'll keep y'all updatedI mentioned this once before, but you'd be wise to inform Mazda of your findings. They would likely have their engineers repeat your fix and test for verification. If they concur with your results, then an official TSB would be posted. This would benefit all the Mazda customers seeking a resolution to this, and maybe even get you something of value from Mazda. Thanks again for posting your fix.
Hello, Thank you for the clear pictures they were helpful for locating the spots. The revised USA TSB includes the spots you pointed out and one extra. I hammered all 12 spots, did the greasing between the firewall and frame. No more noise:banana 1:Hello Mazda family.
I had this noise comming out of the A pillar too after 4000km.
In Czech Republic (Europe) is actually a TSB from 18.8.2014 and I tried it by my self. TSB is: R001/14BCS
I must say,that It works and the A pillar is now quiet,but I only run 100km after this adjustment.
There are 5 more points that needs a hammer treatment (yellow lines).
I have this TSB only in Czech language,but look on the pictures where are the points that needs to be smashed and where is a body work glue required.
Best regards for Czech Rep.
John
