Skyactive 1.5D engine service.
5.8K views 6 replies 3 participants last post by  jamazda3
#1 ·
Hi everyone. Excuse my English.
I would like to ask if there is a specific service manual for the 105hp 1.5D engine, i have a Mazda 3 BM 2016. I searched on the net but I only find what concerns the 2.2D. there are substantial differences between the two engines and also the position of the various components is not the same. Thanks in advance for any information on this. Thank you.
:unsure:
#2 ·
#3 ·
The following links may be of help... ;)
Fuel filter water draininghttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2777600.html
Engine cover removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0110q2804300.html
Battery removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0117q6800500.html
Fuel filter removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2800000.html
Fuel filter disassembly/assemblyhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2485100.html
Before service precautionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2802000.html
After service precautionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2801900.html
Negative battery cable disconnection/connectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0117q6800800.html
Battery inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0117q6800600.html
Battery recharginghttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0117q6800700.html
On-board diagnostic testhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0102q2801000.html
PCM inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2113900.html
Relay inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id092100800300.html
Relay locationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id092100800600.html
Camshaft position (CMP) sensor inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2110100.html
Camshaft position (CMP) sensor removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2110200.html
Power window system initialization procedurehttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091200004100.html
Tire pressure monitoring system initialization procedurehttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id021200204000.html
Wheel and tire specificationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id021200800100.html
Battery condition initialization setting (i-stop setting)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0117q6801000.html
PCM configuration (using as-built data)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2816600.html
PCM configuration (using read-write function)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2816500.html
Engine oil replacementhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0111q2800400.html
Engine oil data resethttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2444700.html
OBD read/clear diagnostic test resultshttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0102q2816300.html
Clearing DTChttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0102q2865400.html
Compulsory diesel particulate filter regenerationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2993400.html
Fuel injector injection amount correctionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2421700.html
KOEO/KOER self testhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0102q2801200.html
PCM data resethttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2810000.html
Fuel injector code programhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2444900.html
Immobilizer system-related parts programminghttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091400514700.html
Air bag system service warningshttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id081000802400.html
Start stop unit configuration (using read/write function)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091400112500.html
Start stop unit configuration (using as-built data)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091400112600.html
Forced ignition onhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id092100802500.html
Air bag system service cautionshttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id081000802300.html
Driver-side air bag module removalhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id081000808000.html
Flowcharthttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id080200080400.html
Driver-side air bag module installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id081000808100.html
Column cover removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700800800.html
Light switch removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091800802800.html
Wiper and washer switch removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091900800200.html
Clock spring removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id081000802000.html
Clock spring adjustmenthttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id081000802100.html
Intermediate shaft removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id061300803100.html
PID/data monitor table (instrument cluster)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0902e8960700.html
Electric power steering (EPS) on-board diagnosishttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id060200813500.html
On-board diagnosis (dynamic stability control) (DSC)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0402b2800200.html
DTC inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id080200080500.html
Brake fluid air bleedinghttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041100815300.html
Brake hose (front) removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041100190300.html
Brake fluid pressure sensor inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041500801500.html
DSC HU/CM removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041500801000.html
DSC related parts sensor initialization procedurehttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041500870200.html
Brake pedal inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041100801100.html
Brake pedal removal/installation (R.H.D.)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041100801252.html
DSC off switch inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041500802000.html
Front side trim removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700802400.html
Front scuff plate removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700801400.html
Parking brake switch inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041200800700.html
SAS control module configuration (using as-built data)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id081000890300.html
SAS control module configuration (using read/write function)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id081000891500.html
MRCC initialization setting (Mazda radar cruise control (MRCC) system)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0120g0012800.html
Parking brake lever adjustmenthttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041200801500.html
Parking brake lever inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041200800900.html
Parking brake lever removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041200801600.html
SAS control module removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id081000801400.html
DTC tablehttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id080200080700.html
Steering wheel and column removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id061300801400.html
EPS control module inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id061300802400.html
DSC HU CM inspection
Rear ABS wheel-speed sensor inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041500800200.html
Front ABS wheel-speed sensor inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041500800400.html
Front ABS wheel-speed sensor removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041500800300.html
Mudguard removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091600467600.html
Front under cover no 1 removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091600888800.html
Splash shield removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091600808400.html
Wheel hub steering knuckle removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id031100800400.html
Front wheel alignmenthttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id021100800200.html
Front crossmember removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0213008010f3.html
Front under cover no 2 removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091600888900.html
Front stabilizer removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id021300800400.html
Exhaust system removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0115q2800200.html
Upper panel removalhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700865000.html
Upper panel installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700866000.html
Rear console removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700898500.html
Manual transaxle shift mechanism removal/installation (C66M-R)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0516c6160800.html
Shift panel removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700898400.html
Front console box removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700803900.html
CD player removalhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id092000035000.html
CD player installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id092000035100.html
Side wall removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700805400.html
Glove compartment removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700800700.html
Decoration panel removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700806600.html
Front console removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700457400.html
Lower panel removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700801100.html
Bonnet release lever and release cable removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091400006600.html
Fuel filler lid opener and lever removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091400510700.html
Trunk side trim removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700803100.html
Exhaust shutter valve initializationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2498600.html
Engine coolant replacementhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0112q2800600.html
Engine coolant leakage inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0112q2800500.html
Engine coolant level inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0112q2800300.html
Steering gear and linkage removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id061300801700.html
Front lower arm removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id021300800600.html
Engine mount disassembly/assemblyhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0110q2806900.html
Oil pan removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0111q2800200.html
Engine oil level inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0111q2800500.html
Intake air system removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0113q2801900.html
Relay and fuse block removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id092100498600.html
Trunk covering removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700462500.html
Trunk board removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700810000.html
Trunk end trim removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700803400.html
Rear seat cushion removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091300912600.html
Rear seat back removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091300912400.html
Rear center seat belt removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id081100800900.html
Rear seat back frame removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091300912500.html
Rear seat back latch removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091300809400.html
Rear seat center armrest removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091300812200.html
Rear package tray removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700020000.html
Rear scuff plate removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700801500.html
Tire house trim removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700802700.html
Trunk side upper trim removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700803200.html
Dashboard under cover removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091700807200.html
Set plate removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091000878900.html
Front bumper removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091000800300.html
Discharge headlight service warningshttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091800804900.html
Front combination light disassembly/assemblyhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091800816000.html
Headlight aiminghttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091800800400.html
Shoud upper member removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091000889800.html
Horn removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id092200012600.html
Front fender insulator no 1 removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091000804100.html
Bonnet latch removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091400006400.html
Bonnet adjustmenthttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091000407300.html
Bonnet removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091000407200.html
Front fender panel removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091000801000.html
Bumper slider removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091000822500.html
Front fender molding removal installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091600802100.html
Crash zone sensor removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id081000800500.html
Radar sensor removal/installation (MRCC)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0120g0012400.html
Radar sensor aiming (MRCC)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0120g0012500.html
Rear combination light removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091800801000.html
Rear bumper removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091000800700.html
Rear vehicle monitoring radar aiminghttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id092200015000.html
DTC inspection (rear vehicle monitoring system)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0902z2345400.html
DTC table (rear vehicle monitoring system)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0902z2347100.html
Clearing DTC (rear vehicle monitoring system)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0902z2400300.html
Blind spot monitoring (BSM) radar testhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id092200014000.html
DTC table (blind spot monitoring BSM)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0902i3960500.html
DTC inspection (blind spot monitoring BSM)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0902i3960300.html
Clearing DTC (blind spot monitoring BSM)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0902i3960400.html
Parking light bulb removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091800804200.html
Headlight bulb removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091800800500.html
Igniter removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091800814200.html
Discharge headlight control module removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091800805300.html
Front drive shaft removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id031300802500.html
Intake shutter valve removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0116q2708200.html
Intake shutter valve initializationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2993200.html
Mass air flow (MAF) sensor intake air temperature (IAT) sensor no 1 removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2900300.html
Mass air flow (MAF) sensor data resethttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2810100.html
Water cooled charge air cooler removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0113q2702500.html
EGR pipe removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0116q2810000.html
Manifold absolute pressure (MAP) sensor boost air temperature sensor removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2801000.html
Engine coolant reserve tank removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0112q2700700.html
HP-EGR control valve removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0116q2702800.html
Water cooled charge air cooler coolant replacementhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0112q2702200.html
Water cooled charge air cooler coolant level inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0112q2702100.html
Water cooled charge air cooler coolant leakage inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0112q2702300.html
Water cooled charge air cooler reserve tank removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0112q2702400.html
Intake air temperature (IAT) sensor no 2 removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2806300.html
Front body control module (FBCM) configuration (using read/write function)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id094000002300.html
Front body control module (FBCM) configuration (using as-built data)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id094000005700.html
Front body control module (FBCM) removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id094000001900.html
Multiplex slow blow fuse removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id092100802400.html
Sunroof system initialization procedurehttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091500858000.html
Manual transaxle oil replacement (C66M-R)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0515m8159700.html
Air fuel ratio (A/F) sensor removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2899700.html
Air fuel ratio (A/F) sensor data resethttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2780800.html
Exhaust gas temperature sensor removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2446400.html
Turbocharger solenoid valve removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0113q2702700.html
Floor under cover removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091600820200.html
LP-EGR control valve removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0116q2702900.html
Exhaust gas pressure sensor removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2443600.html
#4 ·
And these...
Fuel injector removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2800600.html
Fuel injector data resethttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2445000.html
Injection pipe removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2850200.html
Engine disassembly/assemblyhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0110q2800500.html
Timing chain removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0110q2801000.html
Timing chain learninghttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2993600.html
Drive belt removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0110q2801600.html
Drive belt inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0110q2801500.html
Engine tune-uphttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0110q2800600.html
Symptom diagnostic index (engine related)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0103q2052700.html
Symptom diagnostic index (i-loop related)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id1103q4000300.html
Front oil seal replacementhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0110q2800800.html
Turbocharger with variable turbine geometry removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0113q2707500.html
Turbocharger initializationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2993500.html
Electric water pump removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0112q2702000.html
Starter removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0119q2800200.html
Generator (alternator) removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0117q6800200.html
Drive belt auto tensioner removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0110q2362500.html
Manual transaxle removal/installation (C66M-R)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0515m81600d2.html
Clutch unit removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0510ma157200.html
Rear oil seal replacementhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0110q2800900.html
Supply pump removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2805700.html
Lower case removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2266300.html
Common rail removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2803900.html
Glow plug removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0113q2804400.html
Vacuum hose removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id041100801600.html
Vacuum pump removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0411008036t9.html
Oil cooler removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0111q2800800.html
Oil filter replacementhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0111q2800700.html
Engine oil solenoid valve removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0111q2003000.html
Engine oil temperature/Engine oil pressure sensor removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2216700.html
Engine coolant temperature (ECT) sensor removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2111600.html
Crankshaft position (CKP) sensor removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2109600.html
#7 ·
Here's a load more...
Supply pump data resethttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2445300.html
Windshield wiper arm and blade removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091900903100.html
Windshield wiper arm and blade adjustmenthttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091900903200.html
Cowl grille removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091600801000.html
Windshield washer hose removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091900802100.html
Windshield wiper motor and link removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091900001200.html
Cowl panel removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091000802000.html
Keyless beeper removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id091400515000.html
Neutral switch removal/installation (C66M-R)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0515m8159800.html
Back-up light switch removal/installation (C66M-R)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0515m8159900.html
General procedures (front and rear axles)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id031000800100.html
Clutch fluid replacement/air bleeding (C66M-R)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0510ma166800.html
Clutch pipe and hose removal/installation (C66M-R)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0510ma157000.html
Clutch release cylinder removal/installation (C66M-R)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0510ma157100.html
Oil seal (differential) replacement (C66M-R)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0515m8160100.html
Inspection after manual transaxle overhaul (C66M-R)https://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0515m8159500.html
Coolant control valve removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0112q2225000.html
Cooling fan motor removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0112q2801900.html
AC compressor removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0711008010l2.html
Refrigerant system general procedureshttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id071000800300.html
Refrigerant pressure checkhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id071000800600.html
Refrigerant system performance testhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id071000800700.html
Refrigerant recoveryhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id071000800500.html
Refrigerant charginghttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id071000800400.html
Blow-by heater inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2446500.html
Oil pressure inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0111q2800300.html
Exhaust shutter valve inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0116q2812200.html
Exhaust shutter valve removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0116q2703000.html
EGR cooler removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0116q2099000.html
Check valve inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0113q2082800.html
Check valve removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0113q2266000.html
Coolant control valve inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0112q2224900.html
DC-DC converter removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0117q6004600.html
Air fuel ratio (A/F) sensor inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2899600.html
Fan control module inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0112q2801100.html
Fuel tank inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2803200.html
Fuel draining procedurehttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2853500.html
Rollover valve removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0116q2804600.html
Fuel tank removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2801600.html
Quick release connector (emission system) removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0116q2805500.html
Quick release connector removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0114q2801700.html
Fuel gauge sender unit removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id092200012000.html
Coolant control valve position sensor inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2498000.html
Actuator position sensor (turbocharger with variable turbine geometry) inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2497800.html
Intake shutter valve position sensor inspectionhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0140q2217000.html
Check valve (fuel) removal/installationhttps://mazdamanuals.com.au/wsm-secure/WSM/D9G6-1A-21B_Ver17/esicont/srvc/html/id0116q2189700.html
