Loss of acceleration
1.4K views 13 replies 3 participants last post by  alankeith1969
#1 ·
I have a 68 plate cx3 and when I bought it a year ago I was having problems. I lost turbo and was very sluggish. Warning code P2263 turbocharger boost system performance. I have taken it back 4 times. And the fault always came back . I was going ask for a refund but they said it will be fixed. It's now fixed but the acceleration is a bit delayed. Now I have found a bolt has been pushed into a rubber pipe on to of the engine. What did they do to it and what is the rubber pipe for.
#12 ·
Other turbocharged diesel engines have what is effectively a one way valve in the crank case ventilation system, (which works on a vacuum from the intake side of the engine) as there’s actually a pressure (not a vacuum) in the inlet system most of the time. PCV valve? Hope your Mazda dealer / mechanic proves to be a good one and sorts it out for you.
