Infotainment root
1 reading
8.6K views 23 replies 9 participants last post by  ikkoku
#1 ·
Hey guys. I do not want to create this thread but when i look at Infotainment Project, there's so many posts and i dont know where to look. Generally, I have questions.
1. I wonder if we can downgrade our version since i'm currently using stock v31 and i believe i don't have access to SSH since wifi is disabled.
2. In case we can downgrade it, Do we have to do it ourselves or can we ask dealer to downgrade it since we have more trouble with latest version ( just a reason ).
Thanks guys.:balloon::balloon:
#5 ·
#9 ·
It's IMPORTANT to remember.. a simple mistake can cost you a LOT of money since there is NO WAY to recover your infotainment system if something goes wrong.
Should this happen, you have no one to blame but yourself.
YOU ARE RESPONSIBLE FOR THE OUTCOME -- USE AT OWN RISK!!
With that said. Best of luck!!
#18 ·
Right now, not that we know of. There may be a way to force the system to boot into the failsafe mode but it's not openly known what that is.
If you do somehow mess the system up, your best bet is to plead ignorance and pretend like you don't even know what an operating system is. A large majority of maintenance techs are not going to be able to tell the difference between bad hardware and messed up software and will just replace the CMU unit whole. You'll probably have to wait for the part to be shipped in first though.
#19 ·
Right now, not that we know of. There may be a way to force the system to boot into the failsafe mode but it's not openly known what that is. .
I'm pretty sure if it messes up the IT , the only way to get it back will be replacement.
the failsafe is hard coded into the Update, and unless the application calls for it, i don't believe it will be accessable.
From my understanding a reflash of the CMU would be required, using the JTAG port on the CMU itself.
The JTAG port looks like it is Heavily passworded, so I'm almost positive it would need to go back to Mazda for repair (meaning the Tech would probably replace it as he has no way too diagnose)
With that being said --
its a 50/50 chance it will work, with the most probable being the CMU will reject the .UP file as no failsafe for version 29 is currently available.
If it does accept it though.. you really don't need the whole program to work. You just need wifi and ssl access so you can upgrade to ver 31 with wifi and the other mods.
hopefully someone will post a complete version of 29 at some point but currently that is where anyone on version 31 stands.
on a side note:
it may just be wiser to be patient and see if the .UP file can be recoded to accept an already hacked version... to each their own.
Good Luck
