Hesitates going into drive, help!
1 reading
2.3K views 5 replies 6 participants last post by  thzpcs
#1 ·
Hi, I have a 2012 Mazda 3 with the skyactiv engine. It has only 70000 miles on it. I am having a problem whenever I put the car into drive from either park or reverse. It takes about 10 seconds for the car to go into drive and then it jerks forward if I put my foot on the gas. We took it to a local mechanic and he couldn't figure it out. Took it to a Mazda dealer today, they couldn't figure it out. They called Mazda and they told them I need a new transmission!!!!! This is crazy, I don't drive it like a race car driver. What could this be? They wanted $5100 for the new trans!!!! Has anyone out there had this problem and what was the solution?
#2 ·
Have you replaced the old transmission fluid? I'd put in new ATF and see what the shift results are. I dumped my fluid when I had 17k and the fluid was a light brown replaced 9 qts with redline D4 ATF. And every 10k I drain the ATF pan of 3 qts and refill with Redline D4. My 2011 is doing fine. If the replacement of fluid doesn't help I'd check a salvage yard for a 2012/2013 sky transmission from a totaled rear ended Mazda 3.:surprise:
#5 ·
I have the exact same car with only 37000km on it. It happens to me occasionally. Sometimes if I shift too fast from park to drive, or if it's really cold out (-5 Celsius or below). I can tell you though, I drive my car hard. I gun it, and put a lot of unnecessary stress on the tranny, but it sounds like your issue is much more serious if it's happening all the time.
