21 - 32 of 32 Posts
Hi all
I own a new 2020 mazda 3 manual, I want to install my old dashcam, but I didn't want to run a cable through the engine's firewall, neither the USB nor the mirrortap, so this is my solution.
I made a custom relay activated by an accelerometer sensor controlled by an arduino , which can be programmable to behave differently (sensor sensitivity, off delay time, different power mode to save battery life).
The installation is still from inside the fuse box .
What it does is: the relay turns on the dashcam when the sensor detect motion, then when the car stops after a while (10 min for me) it will turn off the dash cam.
So far so good, it works as expected, just to make a couple of tweaks to the arduino code.
let me know what you guys think
278897
278900
278899
278902
278903
278904
Hi all
That's pretty cool. How has it been holding up? Have you made any changes?
2023 M3 awd. Trying to find a way to install power for dashcam. I am thinking to use fuse tap.
Just winder which fuse number generally people will use.?
Is Mazda using micro, micro2, or mini type of fuses., so I can get the proper tap?
Is it a problem if I routing usb wire through the A pillar.?
thx in advance.
I got these and I think I used a red one to connect to the wire, above the internal fuse box, that is for the wireless charging pad. I think the wire is red with another white wire spliced to it for the wireless charger. I saw a forum post somewhere with pictures, but I can't find it now. I used a fuse tap for the constant power. I don't remember which fuse I used, but they are always hot.
I found the forum post that I used to help me install my dashcam without going through the firewall or messing with the mirror.
21 - 32 of 32 Posts
