Change configuration (explore different functions ASbuilt)
2 reading
3M views 7.3K replies 719 participants last post by  bryan065
#1 · (Edited)
With a cruise like understood. Has come time for other useful functions.
I ask all who have a desire to connect to study.
Study SSU:
731-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B1 - it is (in BIN):
b7 - 0 or 1 = function is not known
b6 - 0 or 1 = function is not known
b5 - 0 or 1 = function is not known
b4 - 0 or 1 = 0 - I-Stop OFF, 1 - I-Stop ON (Tested on CX5)
b3 - 0 or 1 = function is not known
b2 - 0 or 1 = function is not known
b1 - 0 or 1 = function is not known
b0 - 0 or 1 = function is not known
B2 - configuration mode wireless control (step-by-step opening):
b7 - 0 or 1 = 0-W/O Advanced Keyless Entry; 1-W Advanced Keyless Entry
b4 - 0 or 1 = 1-W Unlock mode (2-step); 0-W/O Unlock mode (2-step)
b2 - 0 or 1 = 1-W Unlock mode (2-step); 0-W/O Unlock mode (2-step)
731-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
B0 - it is (in BIN):
731-01-03 B0 B1 B2 B3 (checksum) in HEX
B0 - wireless mode lock/unlock is ONLY displayed on monitor (for example it is possible to configure only display the "unlock Mode"(step-by-step opening) or together with "Lock when leaving car":
b6 - 0 or 1 = 1- NO visibility Lock when leaving car; 0 - visibility Lock when leaving car
b4 - 0 or 1 = 1-Visibility Unlock mode
b2 - 0 or 1 = 1-Visibility Unlock mode
Study RBCM:
7B7-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = 0 - no auto door lock or 1 - auto door lock (activates door lock function in RBCM)
b4 - 0 or 1 = function is not known
b3 - 0 or 1 = 0 - 1x blinker when doors close from remote control or 1 - no blinker when doors close from remote control
b1 - 0 or 1 = 0 - no blinker when doors open from remote control or 1 - 3x blinker when doors open from remote control (w/alarm system)
B4 - it is (in BIN):
b6 - 0 or 1 = 0 - OFF 1 - ON (ability to lock doors when Ignition ON) tested on CX5
b3 - 0 or 1 = 0 - OFF 1 - ON (ability to lock doors when doors open) tested on CX5
b1 - 0 or 1 = 0 - if engine work then not possible open boot or 1 - if engine work then possible to open boot (from button on boot)
7B7-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = no data on use
b6 - 0 or 1 = 0 - OFF Find My Car or 1 - ON Find My Car (Press lock button twice on remote controller, You will hear a shortly horn) tested on CX5
b5 - 0 or 1 = 0 - It does not allow to open the trunk in the Drive mode (D) or 1 - It allows you to open the trunk in the Drive mode (D) tested on CX5
b4 - 0 or 1 = no data on use
b3 - 0 or 1 = no data on use
b2 - 0 or 1 = no data on use
b1 - 0 or 1 = no data on use
b0 - 0 or 1 = no data on use
b6 - 0 or 1 = no data on use
b5 - 0 or 1 = 0 - no auto door lock or 1 - auto door lock (only for visible this function on CMU)
b3 - 0 or 1 = 0 - auto door lock or 1 - no auto door lock (only for visible this function on CMU)
7B7-01-03 B0 B1 B2 B3 B4(checksum) in HEX
b5 - 0 or 1 = Lighting Coming Home Light - ON
b4 - 0 or 1 = Lighting Coming Home Light - OFF
Study IC:
720-01-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B2 - it is (in BIN):
b6 - 0 or 1 = 0 - OFF Beeper driver seat belt; 1 - ON Beeper driver seat belt
b5 - 0 or 1 = 0 - OFF Beeper passenger seat belt; 1 - ON Beeper passenger seat belt
b4 - 0 or 1 = 0 - disable I-Stop; 1 - enable I-Stop (enable/disable button I-Stop and view logo "I-Stop" on Instrument Cluster)
720-01-02 B0 B1 B2 B3 B4 B5(checksum) in HEX
b7 - 0 or 1 = 0 - Digital display Cruise control on IC; 1 - NO digital display Cruise control on IC
720-04-01 B0 B1 B2 B3 B4 B5(checksum) in HEX
B0:B1 - it is checksum for full configuration of car (IC)
720-04-14 B0 B1 B2 B3 B4 B5(checksum) in HEX
b5 - 0 or 1 = 1 - W ALS (Headlight Auto Leveling System); 0 - W/O ALS
b4 - 0 or 1 = 1 - and if b5 = 0, then AFS and ALS (Adaptive Front Lighting system) is OFF, if b5 = 1, then AFS and ALS is ON; 0 - and if b5 = 1 then only ALS is ON
720-04-23 B0 B1 B2 B3 B4 B5(checksum) in HEX
b6 - 0 or 1 = 1 - Cruise Control with LIM
b5 - 0 or 1 = 1 - Standard Cruise Control/MRCC
b4 - 0 or 1 = 1 - W/O Cruise Control/MRCC
720-04-24 B0 B1 B2 B3 B4 B5(checksum) in HEX
b5 - 0 or 1 = 1 - SCBS ON; 0 - SCBS OFF
b4 - 0 or 1 = 1 - SCBS OFF; 0 - SCBS ON
720-04-27 B0 B1 B2 B3 B4 B5(checksum) in HEX
b3 - 0 or 1 = 1 - REAR CAMERA with DYNAMIC ASSIST LINES (7 wires) ; 0 - REAR CAMERA with FIXED ASSIST LINES (4 wires)
for example:
edit string in configuration
7B7-01-03 0018 5400 2E
on
7B7-01-03 0018 9000 6A
adds features:
- RAIN SENSING WIPER
- AUTO HEADLIGHT ON
String 7B7-02-01 no need to change. This string enables/disables activated features, it can be done in media settings.
Connect to study.
#415 ·
I am in trouble.
I just tried to discover what bit enable autodoorlock on my M2 changing asbuilt on BCMM. Suddenly FORScan said incompatible configuration when I press write. When I try to write original AsBuilt, the same message!!! By now, I disabled rain and light sensors!!!
Help please, @Withe
Thanks
FORScan version 2.3.4
#418 ·
I wonder if it's possible to activate Gear Switch Suggestion with this method.
You know, when you're in Manual transmission mode, and you go up to 6000 RPM, it will suggest switching to a higher gear.
For some reason, I don't have it enabled, though I do have the necessary digits on the screen.
You can see how it looks here:
owns 2015 Mazda 3 Touring+
#419 ·
Hello,
after presenting myself in the new members section and sucessfully activate Auto door lock in my Mazda 3 I want to go ahead withsome more mods.
I would like to activate HBC, I have bi-xenon kit but I have not been able to find module 706 with ForScan (as indicated previously by rmaqui).
The other feature I want to activate is Rear Cross Traffic Alert, as I have rear vehicle monitoring I think it is only a matter of finding the bit in RVM module (07-C4-01, I think)
I have a Mazda 3 luxury (this is the way they call the high end model in Spain) with bi-xenon, rear vehicle monitoring system, cruise control but with no adapatative cruisse control (no radar) and I think that I have Forward sensing camera as it can be seen through the windshield and I have colission assist activated.
Any help would be appreciated, thanks in advance, you are great.
#432 ·
@Withe in a post you said not possible to hability double lock mode in a car w/o advanced keyless entry system but in this photo i can see Its possible to activate it in both entry system.
Enviado desde mi iPhone utilizando Tapatalk
I know, but I couldn't find necessary data
#439 ·
Setting doors locks
Hi, Withe.
I am coming from the
clubmazdacx5
as other companions in this forum, I am a user of CX-5 and I will like to help you to study the SSU in order to activate the two step openning function.
I have read more or less all the post that you have here and I have understood the difficult to find information.
After reading and seen some information about the CX-5 from USA, I think that they have the door lock menu activated from factory.
So I have looked for VIN numbers in USA from sellers and I have AsBuiltData from mazda.
I hope it will be useful.
BUT I CAN NOT ATTACH THE ZIP FILE
My best regards and thanks to all participants in these forums.
JM3KE2DY5G0601458 JM3KE4BE9E0372333 JM3KE4DY6F0501928 JM3KE2DY1F0548112 JM3KE4DY8G0849571
JM3KE4DY8G0829188 JM3KE4DY0G0856417 JM3KE4DY3G0829504 JM3KE4DY9G0841186 JM3KE4DY9G0822623
JM3KE4DY3G0824223 JM3KE4DY1G0845328 JM3KE4DYXG0847773 JM3KE4DY3G0864589 JM3KE2DY4G0808052
JM3KE4DY3G0854760
#444 · (Edited)
Hi, Withe.
clubmazdacx5
JM3KE4DY3G0854760
I think you found VIN without Advanced Keyless Entry but with Unlock mode (2-step)
It is JM3KE4BE9E0372333
731-01-01 0005 5484 2037
731-01-02 0008 0648 A031
731-01-03 5421 00B1
so same without I-Stop
#464 ·
Hi,
You can export the configurations for each module in a separate file using forscan
The 706-02 block has something related with the activation status of HBC.
With HBC suposedly activated, 706-01-02 has the same value as 706-02-01 but if I pick Disable HBC with the interface, the values stores at 706-02-01 change but not the 706-01-02.
I just want to confirm that theres no aditional differences (since the mazda asbuilt website do not show 706-02-01)
