2,701 - 2,720 of 7,282 Posts
Hi
I have the new Mazda3 BN petrol engine 2.0 AT,120cv, and i ask if can configure doorlock over 20km/h? i am from Portugal.sorry for write,i buy a elm237 modified ms-can,can i have help ,please
cmps
zé
Yes i think you can,
my car same as your's but is manual transmission, i only have 2 options on my autolock door but since your car
is automatic you will get more options, like Lock:Out of Park, Unlock: In Park<--- that the one i love if i had it :crying2:
Im Portugueses to btw
@joe_wang2018
I saw that you edited the original message
Tell as please did you manage to reset messages about malfunction of SBS / SCBS / MRCC? And does Forward SCBS work properly after these errors resseting?
To enable Stop&Go MRCC:
I got my brand new 2018 CX5 few months ago, which is equipped with non-Stop&Go MRCC. Sadly, the 2019 model was just coming out last month with Stop&Go MRCC. When I compared IC asbuilt for both vehicles bit by bit and confirmed only 2 bits are different, which are b1 of B2 and b2 of B4 on 720-04-17. The CX5 without Stop&Go MRCC whose b1 of B2 is 0 and b2 of B4 is 1, while the CX5 with Stop&Go MRCC simply inverts above bits from 0 to 1 or 1 to o.
I tried to change these 2 bits on my CX5 and Forscan write successfully, but turned out to be no luck and the info panel just showed the malfunction of SBS/SCBS/MRCC.
Any advise or suggestion that I can give another try will be appreciated!!!
Joe Wang
Hello
Can someone help me to change this values for auto door lock on?
Change configuration
I connected the Forscan into my 2014 Mazda 6 2.2D Skyactive MT and I have this data from R-BCM (AS BUILT Format):
7B7-01-01 9D52 0006 E196
7B7-01-02 8707 D300 082A
Could someone send me the data changed for the setting that I want the install on my car?
It will be a great help!
Thanks in advance,
Thanks in advance,
Change
7B7-01-01 9DD2 0006 E116
7B7-01-02 8707 D300 2042
And don't forget to do "reset" in door lock menu
Hello Nashsiz,
Can you teach me step by step how to do the calculations of the values that you gave me?
Thanks in advance
Regards
Ok. Use this guy's xls file. Post http://mazda3revolution.com/forums/...3-change-configuration-explore-different-functions-asbuilt-258.html#post2349274
Link to the xls file download at the bottom of the post.
In the file - use the rbsm tab. Fields need to be filled with yor R-BSM 7B7-01-01 and 7B7-01-02. This is "ORIG"
And change the right side of everything that relates "Door lock".
In the picture your configuration "Before and" After"
Is there anyone who owns 18+ M3 or 17+ CX5 with Advanced SCBS? and can kindly send me the FSC and IC.abt. I try to figure out what bits are involving to switch between Advanced SCBS and ordinary one. Thanks
This video was demonstrating how A-SCBS can detect pedestrian and apply brake automatically
what do you mean by "ordinary one"
What does ordinary SCBS do?
