2,661 - 2,680 of 7,282 Posts
Hi Diamonds,
I own a 2018 flagship model of CX5 equipped with all types of security features like MRCC, LDA, LDWS... Let me know, if you want me to send you all of my Asbuilt data for your reference.
Joe Wang
Hello everyone,
I have CX5 2018 and I would like to add LDWS, HBC and MRCC. I tried a lot of combinations from this forum, but no sucessfull.
Who will resolve this problem? As a present, I can give 100UDS or something better - Unlimited Access to wiring for CX5 2018 - Full wiring for all KF types (petrol, diesel).
TSR has been activated on my 2018 CX5 with Navi SD installed
Although the Navi SD can also show speed sign on HUD but it is merely based on the map data rather than the real traffic sign recognition. By simply changing b4 bit of 706-01-02's B4 from 1 to 0, my 2018 CX5's FCS can see the speed limit sign now.
Is it possible to unlock SCBS to A-SCBS?
I used to drive the Volvo and really like its Pedestrian detection feature. Is it possible to unlock SCBS to A-SCBS on 2018 CX5 ? or can someone kindly share your FSC asbuilt (A-SCBS) to me for comparison?
Any helpful info will be highly appreciated
Joe Wang
Don't stop at the first light error. Turn off and on again, two or three more times
Sometime errors disappear..
Check also your DTCs and see if you can clean them and if they come back.
Maybe you'll have to modify value somewhere else... Is There any Lidar module same as the FSC one?
I will recommend to relearn ABS and MRCC radar procedure after this has been done.
this should clear all the errors
To enable Stop&Go MRCC:
I got my brand new 2018 CX5 few months ago, which is equipped with non-Stop&Go MRCC. Sadly, the 2019 model was just coming out last month with Stop&Go MRCC. When I compared IC asbuilt for both vehicles bit by bit and confirmed only 2 bits are different, which are b1 of B2 and b2 of B4 on 720-04-17. The CX5 without Stop&Go MRCC whose b1 of B2 is 0 and b2 of B4 is 1, while the CX5 with Stop&Go MRCC simply inverts above bits from 0 to 1 or 1 to o.
I tried to change these 2 bits on my CX5 and Forscan write successfully, but turned out to be no luck and the info panel just showed the malfunction of SBS/SCBS/MRCC.
Any advise or suggestion that I can give another try will be appreciated!!!
Joe Wang
The part# of my CX5's Radar/Distance Sensor:
