Hi all
I have HATCBACK MAZDA 3 2014
my idea is add at the standard/factory MAZDA interior and cargo light the aftermarket LED.
I tryed to connect a COB LED in parallel at the cargo light in my hatchback mazda 3.
But after connect in parallel I turn on the switch, but the MAZDA light and new LED is always OFF.
After I removed and checked the Mazda bulb and work correctly with power supply 12V.
I checked the voltage on the 2 wire of the power connector of cargo light and voltage is 6,7 volts not 12 Volts.
some questions:
1) How solve this problem ?
2) this is CAN BUS error ?
3) rear body control unit damaged ?
4) fuse damaged ,where is located the exact fuse for cargo light ?
5) other ?
6) where I find (connector & wire ) always 12 volt in the car ( the car is OFF , not ACC, and not ON ) to add the aftermarket LED , at standard MAZDA cargo light ?
My idea is add LED lights ( welcome light ) in feet area for driver & passenger and for rear passenger.
this added lights work when work the interior MAZDA light, when is open and close the door.
these is the LED
http://www.aliexpress.com/snapshot/6719644484.html?orderId=67676919746437
http://www.aliexpress.com/snapshot/6817662598.html?orderId=68467461786437
thanks
some questions:
5) other ?
these is the LED
thanks
