hello everyone. wrote these 4 beginners guides during my time over at a hyundai site while i still owned my old accent. i do recognize that these newer cars don't require much, but the day will come. many found these guides useful, maybe someone here will too. although they are a little hyundai-centric, they are written to be very general and apply to any vehicle.
ZERO 101: AUTO REPAIR SAFETY
Welcome to my first beginner's guide to automotive repair. this guide is intended for novices, and as such your first concern should be your own safety and the safety of others around you. yes, i know...this is boring! it's also very necessary, so i'll try not to put you to sleep and keep this brief!
"I take no responsibility for any damage or injury that may be caused by your use of this guide. this is meant to be a reference to improve your safety practices. i cannot be responsible for your actions and mistakes"
SECTION 1: LIFTING HAZARDS
the biggest concern you will have here is getting under the car. this is very necessary for repairs, but also can be very dangerous. let's face the facts here: if that car falls on you while you are underneath it, you can die! for this reason, jacking the car up and getting under it should be taken with the utmost concern. any car can roll off its supports and fall if not secured properly.
the short of this is always use wheel chocks, parking brake/trans in park (1st gear for manuals) and always use solid or positive locking supports.
let's start with a few methods, do's and don't.
drive on ramps
for convenience, nothing beats these. just as they look, drive up on them. block your opposite wheels and you're done. they have ridges on either side of the flat surface to prevent rolling. great for quick oil changes.
downsides: can't remove your wheels or work on suspension. major jobs are out of the question. you have to be VERY careful positioning the ramps before driving on otherwise you can drive off them. it also takes a bit of practice to use them right as you have to give it a bit of gas to get up the ramp and then stop on the flats once the front wheels are over the stop ridges.
zero's experience: you can drive over these and end up with them under your car if you're not careful. yes, i have done this.
hydraulic jacks and jack stands
notice i lump hydraulic jacks and jack stands under the same category. this is because hydraulic jacks should never be relied on for safe support of your car ever!! these can slip, hydraulics fail, and then you could wind up dead. this happened to my old landlord years ago and he ended up stuck under his truck for several hours until someone could rescue him. luckily, the vehicle was high enough not to have crushed his skull - barely. he still has the scar. avoid the temptation of speeding through your setup.
in short, never get under a car supported only with hydraulic jacks! use jack stands!
always use wheel chocks to prevent vehicle rolling
if the wheels are on the ground, use either parking brakes or transmission in park (1st gear for manuals)
only raise a vehicle on level ground
always do a bump test before getting under the vehicle
always use a solid jacking point for your hydraulic jack and jack stands. there are many available, but take note of what is structural and what is not. for example, the gas tank is not such a good point for supporting your vehicle. subframe, as long as you don't need to remove it, is an excellent choice. take note of the following pictures for examples:
This pic is the underside of a hyundai accent, although not mine. i have circled the suitable jack point in black and non suitable in red. take a good look. the black point is solid box welded subframe...it's not going anywhere. it's also flat making it an ideal choice.
the leftmost red circle is the control arm under the wheel. not only could that hinder maintenance, its a pivoting joint with a strut on top of it. the control arm is also made of thin metal designed to crumple in an accident. terrible choice, don't even think about it.
upper middle red circle appears to be a solid point, and yes it is. however, it's the geometry that makes this unsuitable. the upwards bend means we don't have a good LEVEL spot to put a jackstand. also, can't see how this bolts to the frame. no idea if this is able to take full load of the vehicle or not from this view.
rightmost is the exhaust....this seems like a no-brainer but i have seen it attempted. its fastened by rubber mounts and hangs under the car. take a close look and it should be obvious why this is a bad idea.
this pic i believe is from a velositer. ignore the hoist points. although can be suitable, we can't really see what is going on with them clearly. also, see that lip on the outer frame? you might bend that if you don't have the correct equipment.
again, the frame is marked in black. obvious good spots for a jack.
gas tank, terrible place unless you like putting a jack THROUGH the tank. that spare tire well isn't much better.
now, why have i marked off the rear cross member as being a bad idea when i have already stated that its a good idea to use it? (scroll down to camero pic) take a good look at how the suspension is designed. that cross member pivots and is a moving part of that suspension. in short: never use a moving component for support
trolley/hydraulic jacks
there are many different ones out there, pick the one that suits your needs. you don't necessarily need to buy an expensive one. give it a quick check before using it every time. if its leaking oil, that's a dead giveaway. if you aren't sure, don't use it. again, these should NEVER be used to support your car while you are under it. the only exception to this rule is the few that have lock pins. the height can be positively locked with a safety pin, so if the hydraulics fail it doesn't matter.
the purpose of this jack is to get the height you need and then support with jack stands. once on stands, the trolley jack can be removed.
bottle jacks
bottle jacks are not recommended. there is a much higher likelihood of tipping the jack while raising the car. the footprint is much smaller and therefore less stable than a trolley jack. also, the trolley jack will travel a little on its wheels while raising the vehicle. think right angle triangles and Pythagorean theorem. this does not allow for that.
bumper jacks
these are all but extinct now. not recommended. they are a very old design and not commonly used due to the fact that they are inherently unstable in their design and prone to slipping.
jack stands
this is the preferred method to support a vehicle before getting under it or anywhere near it while supported. notice the wide base for excellent support and the locking bar. they are height adjustable and due to the ratchet style height locking design, they cannot slip while under load. only way to retract the supports with the release lever is by removing the load. very versatile and inexpensive. they will also allow you to do any repair.
take note of the following image:
note how the stands are placed evenly apart from vehicle center and a strong structural cross-member was selected to take the load. i would not hesitate to get under this camero!
wheel chocks
many different types and styles out there, but the principle is the same. you're blocking the wheels on the ground so that they are unable to move. if the car rolls, its going to come off ANY support you have no matter how good it is. doesn't matter if your brakes are on, this is your life we're talking about here.
the bump test
this is just my name for it. once the vehicle is supported, how do you know you've done it right? give the car a good bump with your body. throw your weight at it from all sides. if there is even the slightest slipping, DO NOT GET UNDER THE VEHICLE! get your trolley jack back under it so you can reposition your jack stands.
preventing damage
it is possible to cause damage to either your driveway/garage or even the vehicle itself when jacking it up. the weight of the car can bend some supports such as the rear cross member. the solution is easy: spread out the force by using a block of wood. wood can be used under your trolley jack/jack stands, on top or both depending on your application. inspect your wood carefully to ensure no cracks are present. the wood can split under the weight of a car. another alternitive (and safer!) is to use plate steel if you can get your hands on it. i would recommend a minimum of 1/2" to ensure its not going to deform badly under load. this isn't always necessary, experience will teach you when it is. watch your jack points carefully when performing your setup.
never use concrete blocks for support as concrete can crack under weight.
drive on ramps
bottle jacks
bumper jacks
jack stands
wheel chocks
the bump test
preventing damage
