Thanks very much for taking the time to show the bulbs. I should have explained my reason for asking; the manual says I should not try to replace Xenon bulbs on my own as they could be a shock hazard (I am not sure why), but that it is safe for me to replace halogen bulbs on my own.Typically a factory HID will produce a whiter light, as opposed to halogen producing more of a yellow hew. Something like this.
If you're able to take the bulb out, you'll be able to see a significant difference. In this picture, an HID is on the left and a halogen bulb is on the right.
Hope the helps!
My car looks just like the one in your avitar (except mine is white), so I guess I have Xenon. Thanks very much for responding to my question.stand in front of your car. do you have or do not have a seperate column for high beam. yes= halogen. no=bi xenon.
Yeah if you have xenons you can change them out yourself just make sure the car is turned off. A lot of people on the forum change out their bulbs without issues as far as I've seen.My car looks just like the one in your avitar (except mine is white), so I guess I have Xenon. Thanks very much for responding to my question.
That is true the initial voltage to start the bulbs is high but after a few seconds the voltage diminishes a lot. The shock from the voltage wouldn't kill anyone but you're right that it'll be hella painful and wake you up instantly. What kills is the amps anything over .1-.2 amps or 100 mA - 200 mA kills.FYI: The danger of handling HID bulbs is probably because they work by generating an arc using 2000-5000 volts. And, even if they are not on, there is probably potential that they are still "charged". So, like an old TV cathode ray tube, you probably need to make sure to safely ground the terminals before you try to handle the tube. The shock probably wouldn't kill a healthy person, but it would sure wake you up.
no worries mate. i'm surprised you can actually tell if it's the same from that small photo anyway. but if you need to changed the bulbs, access is from the wheel wells. and use the bonnet area to have a look before you access the wheel well area because you pretty much have to use your hands to feel where things are cause it's unlikely you can see through. i've changed my bulbs to the philips ultinon so you're all good to change them by yourself..My car looks just like the one in your avitar (except mine is white), so I guess I have Xenon. Thanks very much for responding to my question.
