It depends on a lot of factors, and you're not too far off from what I get.
- if you have winter tires, that can have a large effect. I notice a substantial difference with mine.
- in winter, the air is obviously cold and more dense. Therefore more fuel is required to maintain the mixture.
-if there's a lot of hills on your drive like mine, it'll compound the problem.
- winter fuel is a little different. They change the additives at the pump to suit the colder climate. Think antifreeze.
- this car tends to guzzle a little in the cold. Once things start to warm up, it'll settle right down.
- when cold, the ecu increases the idle significantly to help warm it up faster. It's only for a short time, but still has an impact. I really notice it with a manual. If you use a block heater you can eliminate this.
-it's possible that the winter weather has given you the gift of a dragging caliper. This is why I lube and check mine in spring and fall regardless of mileage.
I've noticed that this car really likes temps around the 20 C range. I can easily get a little over 5L/100km in that weather. Winter I'm in the same boat as you. I have a 2015 in Canada BTW.
