1 - 2 of 2 Posts
2013 GS-SKY
Bolt Pattern 5x100
Center Bore 57.1
Offset 20
Size 17x8.5
Can I get these to work? I tried reading the guide above, but my brain melted...cause I'm dumb
Thank you for any input you can provide
2013 GS-SKY
Bolt Pattern 5x100
Center Bore 57.1
Offset 20
Size 17x8.5
Bolt pattern won't work without an adapter. Mazda has a 5x114.3 bolt pattern. You can get away with 5x112 but will need special wobble lugs to center it correctly. Offset is low as well. With an adapter & that offset, you will have about an 1.5" - 2" wheel poke past the fender.
My current setup is 18x9.5 et 27 in the front & 18x9.5 et 17 in the rear with spacers f&r. Both front & rear poke past the fender. No drop yet. Stock suspension. No rubbing at stock height whatsoever. Gonna have to roll & pull fenders a good amount for my fitment.
Hope this helps in some way
1 - 2 of 2 Posts
