1 - 12 of 12 Posts
Hi, I have a Mazda 3 2016 with automatic transmission. When I drive at a certain speed 78-80km/h then I hear a whistling/squeaky noise.
The noise only appears when I touch the accelerator slighly. As soon as I accelarate more or when I completely release the accelerator then the noise disappears.
The noise also only occurs when the engine is warm. I did not notice it when the engine is still quite cold.
Does anyone have an idea what could cause the noise? Many thanks
Thanks, but wouldn't a belt/pulley squeak also occur when the engine is cold and on various speed levels?
The whistling noise only occurs when the engine is warm and when I very slightly touch the accelerator pedal (at around 78 km/h)
I kinda wondered about that. Either gear lash isn't right or a bearing is going if that's the case. Keep on them, don't accept no for an answer.
BTW tire rotation will only change where the source of the noise is. Won't solve it.
Sadly no, we couldn't recreate the problem on the day since there wasn't an accessible speedway and time was an issue. I am sending them a recording of the sound until I can book a dedicated day during March.
It's a bit of a worry that a complete transmission change was needed to make the sound go away though!
The tires do not think it's because the steering wheel would vibrate, rather than make noise.
Have you checked the oil levels ?, or have you had an oil change recently in a revision? ... to see if they have put another type of oil with less viscosity. I would aim at the differential.
1 - 12 of 12 Posts
