1 - 11 of 11 Posts
2016 Mazda 3 Sport 2.0 Automatic
Does anyone know CCA and RC for the OEM battery for the 2016 Mazda 3 sedan auto, Sport, No I-eloop, no I-stop. The installed battery on my car is 725 CCA which seems excessive for a small late model engine like this.
The owners manual just says 12v 60 AH/20HR. So at least I know it is 60AH.
Discussion Starter · #2 ·
I found this photo on the internet which seems like the factory OEM originally installed Battery. The 356 CCA seems more reasonable than the 725 CCA I have now. Does anyone knows if this is the battery that the car originally came with?
Motor vehicle Office equipment Telephone Telephony Computer hardware
No such thing as "excessive" CCA. More is always better. Your car should have a group size 35 battery in it. CCA is not part of the battery spec. I believe the OEM battery is something like 525. 356 might not even start the car if its really cold outside even if the battery is new......FWIW my lawn tractor has a 330CCA battery.
This is what I am trying to find out. How many CCA the Mazda 3 came originally. My CRV is 410, Prius 325, Lexus 450. The Mazda CCA is a well hidden secret at all sites but 356 CCA I see on the photo above is not far from other models. My 725 CCA battery is group 24F so the previous owner changed the group 35 Original battery.
My car has an OEM group size 35 Panasonic 55D23L battery. CCA isn't listed on the battery but that battery is supposed to be rated at 540 CCA.
As long as its working, there is nothing wrong with the battery you have.
One concern with the high CCA oversized battery is that it could cause the alternator to run at higher temperatures and shorten its life.
Truth is that no alternator damage occurred yet using the 725 CCA battery for 3 years now. Plus this morning at 10 degrees the car started after cranking just under 2 seconds.
Uh, what? Never heard anybody make that claim. CCA ratings have nothing to do with the alternator. Its a measure of power output capability.
Discussion Starter · #8 ·
Batteries don't "pull amps" from the alternator. The alternator sends a charging current to the battery according to its output capacity and the state of charge of the battery. All it does is charge the battery as needed. It doesn't care how many CCA the battery can provide, nor does it cause any extra wear.
Yep and it could even be argued that a large battery evens out peak loads on an alternator and extends the charging system life.
I think the oem was 550, sounds like you are in a cold state and the original owner changed it out for cold state effect. It's common practice in cold states to swap out the battery with something bigger to handle the cold winter mornings a bit better. If it's working well, leave it alone.
1 - 11 of 11 Posts
