1 - 20 of 20 Posts
Weapon-R would like to say Hello to all the members here and start off by posting some of our new products just released!
Weapon-R Is pleased to announce a new product to its product line. The I-Throttle will allow adjustments of throttle response on Drive by Wire vehicles.
16 Way Adjustability:
+9 Way Power Advance
+7 Way Economy Advance
$148 for I-Throttle Unit and Harness for your application
Plug and Play Harness for :
Nissan / Toyota / Mazda / Honda / Acura / Infinity
/ Mitsubishi / Scion / Subaru / Suzuki / Lexus
Our First Crossover with our friends over at FATLACE / HELLAFLUSH..
Made from 6061 Billet Aluminum.
Hardened Steel Wheel Studs.
This will be for sale weapon-r.com..
Sizes for most fitments for:
4 x 100 / 5 x 100 / 4 x 114.3 / 5 x 114.3 / 5 x 112
Thickness available:
15mm $105
20mm $110
25mm.. $114
Studs: M12 x 40mm x 1.5 pitch.
Hub Centric Sold Separately.
Weapon-R Aluminum Bolt and Washer kit.
Available in Blue , Purple, Black chrome, and Silver.
Comes with 10 bolts and 10 washers!
$25 for the set
Chris Wanstrath
650-877-8280
[email protected]
Please visit Weapon-R for more parts for your vehicle!
Is it compatible with the new mazda 3 with the 2.5??? What does it do exactly??? I would like to see the product dynosheet...
I doubt there is any HP gain off it. Read up on the Sprintbooster, I am thinking it is the same idea. Just a signal amplier. So the car revs up faster, meaning it gets to full throttle before the pedal is down. I am just guessing but it seems to be the same idea as the Sprintbooster
You are correct allows control of the throttle response.
^ Yes, header and intake manifold would be nice. I read up a little on the Sprint Booster and the company claims it doesn't lower 0-60 times but it improves throttle response and gives quicker acceleration. Does that make sense? How are these installed anyway?
So with this mod, you would feel faster but not actually gain any performance? Would this work on the 2.5 auto? I saw the price of $150 plus $25 for PNP harness. Seems affordable.
The jury is out if it does much at all, someone wrote a long white paper about the SprintBooster.
Yes there is a performance gain but ideally, it levels out eventually. Because this things ideally lets you get to WOT faster,but at the same time you will get there eventually anyway.
I am curious as to what settings this has. The Sprintbooster, you can raise and lower how much extra throttle control you want. But this thing looks like you could do a lot more with it.
thanks for posting the videos and enlightening us with the products. :)
interested in the wheel spacers myself.
What's the bolt and washer kit for? What size are the bolts?
Discussion Starter #17
The I throttle controls the signal to the drive by wire throttle body. higher performance number the more response. higher economy number the slower the throttle response.
1 - 20 of 20 Posts
