Hi guys hope you can help me with this issue.. I just installed the vled switchback a while ago.. Fitting is perfect, i just have a problem that requieres your help..
The thing is as follows...
Leds work fine without the headlights on they do everything they are supposed to do.. The thing is that as soon as i turn the headlights on.. The drivers side led goes of .. Blinker works fine, the problem is just for the white color when headlights are on.. The passengers side works perfect all the time .. The problem is just on the drivers side..
I switched the bulbs to see if that was the problem but it is not... Same result.
I am running 8k HIDs on headlights...
I disconnected the hid on the drivers side and the leds work fine all the time, is just when HIDs are on... What can it be?? Checked all the connections twice and everything is as it should be... I havent installed the resistors yet
Help will be appreciated .. Thanks
