I find the fog light of my s sport usless except for the aesthetic look.
Can I adjust the beam of the fog light to flow higher?
Has anyone removed the shield inside the housing? Will it blind others?
Yes you can aim them upwards, they are set to lowest setting from the factory.
There's a pivot screw and a tilt screw. The glass is sealed to the foglamp housing so you cannot remove the metal anti-scatter ring from around the bulb. Unless you want to try to get the glass unsealed from the housing.
Sesarch "Fogs" you'll get a lot of info
I have adjusted the fog lights to aim higher. Bcos of the metal anti-scatter ring, it is not as bright as the low beam even I upgrade the bulbs to Silverstar Ulta.
