Hi guys! Yesterday was checking some logs of my Mazda 3 v 33.000.500 (EU) and get some the common codes to track better what are you searching in the massive log file :laugh2: I also add some examples of the logs ;)
NAVI SD system [CODES 1165]
Code:
00:20:50.481 NAVIBLM[1165] Info (navi_sd_detection.c:251 thWatchMount) New device event - action: remove, devnode: /dev/sda1
00:20:50.481 NAVIBLM[1165] Info (navi_sd_detection.c:596 unmountDirectory) Successfully unmounted /mnt/sd_nav
00:20:50.481 NAVIBLM[1165] Info (navi_state_machine.c:1491 navi_stateHandler_Available) SD_REMOVED -> DisconnectingValidCardState
00:20:50.481 NAVIBLM[1165] Info (navi_settings.c:1841 handleHUDControlAllowedStatus) HUD control is NOT allowed
00:20:54.261 NAVIBLM[1165] Info (navi_settings.c:2567 VBS_NAVI_getVIN_Handler) got VIN from signal: HERECOMESTHEVINNUMBER
USB [CODES 1510,1611,446,447,297]
Code:
00:20:50.481 UPDATEA[1611] Info (updatea_usbmgr.c:878 updatea_usbmgr_USBEventHandler) New device event - action: remove, devnode: /dev/sda.
00:20:50.481 UPDATEA[1611] Warn (updatea_usbmgr.c:2240 updatea_usbmgr_ProcessRemoveDeviceEventWithMntLsnr) An USB device with dev file="/dev/sda" is not previously mounted!
00:20:50.481 USBDTC[447] Info (usbdtcudev.cpp:284 UDEVMonitorRoutine)  udev_notif = <True> ; acc_stable_notif = <False>
00:20:50.481 USBMA[1510] Info (usbm_udev.c:656 usbm_udev_get_hub_presence) Monitored device has been disconnected! DevPath:'/sys/devices/platform/fsl-ehci.1/usb2/2-1', devnum: 2
00:20:50.481 DIAG[446] Info (testdiag_statemachine.c:1655 testdiag_DefaultState_EventHandler) TESTDIAG_Default_State exit
00:20:50.481 USBMA[1510] Info (usbm_udev.c:715 usbm_udev_set_status) usbm_udev_set_status OK : <0><0> <1250.540718818> :
00:20:50.481 USBDTC[447] Info (usbdtcudev.cpp:606 ProcessEvent) Monitored device has been disconnected! DevPath:'/sys/devices/platform/fsl-ehci.1/usb2/2-1', devnum: 2
00:20:50.481 DIAG[446] Info (testdiag_statemachine.c:1406 testdiag_ReadyState_EventHandler) TESTDIAG_Ready_State exit
00:20:50.788 USBMA[1510] Info (usbm_am.c:240 cbSignalNotify) audioFocusChangeEvent: streamName:FM
00:20:50.788 USBMA[1510] Info (usbm_am.c:241 cbSignalNotify) audioFocusChangeEvent: streamType:Media
00:20:50.788 USBMA[1510] Info (usbm_am.c:242 cbSignalNotify) audioFocusChangeEvent: newFocus:1
00:20:50.788 USBMA[1510] Info (usbm_am.c:228 cbSignalNotify) Signal name = enableEvent, payload = {"enable":false}
00:20:54.261 USBDTC[447] Info (usbdtcvbuspwrctrl.cpp:713 VINDataUpdate_cb) VIN data 'VINNUMBER' length=17
00:20:54.633 kernel[] Info (: ) [ 1254.637427] usb 2-1: new high speed USB device number 4 using fsl-ehci
00:20:54.780 USBMA[1510] Info (usbm_udev.c:624 usbm_udev_get_hub_presence) Monitored device has been connected! devnum:4
00:20:54.780 USBMA[1510] Info (usbm_udev.c:715 usbm_udev_set_status) usbm_udev_set_status OK : <1><4> <1250.540718818> :
00:20:54.780 USBDTC[447] Info (usbdtcudev.cpp:284 UDEVMonitorRoutine)  udev_notif = <True> ; acc_stable_notif = <False>
00:20:54.780 USBDTC[447] Info (usbdtcudev.cpp:576 ProcessEvent) Monitored device has been connected! devnum:4
00:20:54.780 USBDTC[447] Info (usbdtcvbuspwrctrl.cpp:441 StopRecoveryCycles)  StopRecoveryCycles
00:20:54.780 USBDTC[447] Info (usbdtcapp.cpp:362 StatusChange) Status changed DTC ID = 32, isAsserted = 0
00:20:54.780 kernel[] Info (: ) [ 1254.787991] usb 2-1: New USB device found, idVendor=0424, idProduct=2640
00:20:54.780 kernel[] Info (: ) [ 1254.788009] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
00:20:54.780 kernel[] Info (: ) [ 1254.790512] hub 2-1:1.0: USB hub found
00:20:54.780 kernel[] Info (: ) [ 1254.790719] hub 2-1:1.0: 3 ports detected
00:20:54.780 kernel[] Info (: ) [ 1254.791439] usb 2-1: authorized to connect
00:20:54.780 kernel[] Info (: ) [ 1254.793379] hub 2-1:1.0: USB hub found
00:20:54.780 kernel[] Info (: ) [ 1254.793598] hub 2-1:1.0: 3 ports detected
00:20:54.788 VBS_BUS_DIAG[297] Info (mod_diag_manage_svc.c:980 VBS_DIAG_ClearFaults_Request_svc) Number of Faults passed to ClearFaultsRequest  : 1
00:20:54.788 VBS_BUS_DIAG[297] Info (mod_diag_manage_svc.c:993 VBS_DIAG_ClearFaults_Request_svc) Fault 1 is 32  - USB_PORT_HUB2_MISSING_MSG
00:20:54.788 USBDTC[447] Info (usbdtcreporter.cpp:226 ReporterRoutine) VBS ClearFault successful! FaultID = 32
00:20:54.788 VBS_BUS_DIAG[297] Info (mod_diag_manage_svc.c:2170 VBS_SendSignal_ClearDTCResp) Current page : 0, Total page : 0  and Response Length is 4
00:20:54.788 VBS_BUS_DIAG[297] Info (mod_diag_manage_svc.c:2267 VBS_SendSignal_ClearDTCResp) Fault ID is 32 - USB_PORT_HUB2_MISSING_MSG and fault status is 1
00:20:54.810 kernel[] Info (: ) [ 1254.818614] wl12xx: firmware booted (Rev 7.3.10.10.136)
00:20:55.060 kernel[] Info (: ) [ 1255.067605] usb 2-1.1: new high speed USB device number 5 using fsl-ehci
00:20:55.220 kernel[] Info (: ) [ 1255.232960] usb 2-1.1: New USB device found, idVendor=0424, idProduct=4040
00:20:55.220 kernel[] Info (: ) [ 1255.232980] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
00:20:55.220 kernel[] Info (: ) [ 1255.232995] usb 2-1.1: Product: Ultra Fast Media Reader
00:20:55.220 kernel[] Info (: ) [ 1255.233007] usb 2-1.1: Manufacturer: Generic
00:20:55.220 kernel[] Info (: ) [ 1255.233017] usb 2-1.1: SerialNumber: 000008264001
00:20:55.224 USBDTC[447] Info (usbdtcudev.cpp:284 UDEVMonitorRoutine)  udev_notif = <True> ; acc_stable_notif = <False>
00:20:55.280 kernel[] Info (: ) [ 1255.289357] usb 2-1.1: authorized to connect
00:20:55.280 kernel[] Info (: ) [ 1255.292814] scsi1 : usb-storage 2-1.1:1.0
00:20:55.810 USBMA[1510] Info (usbm_am.c:228 cbSignalNotify) Signal name = enableEvent, payload = {"enable":true}
BLUETOOTH [CODE 2702]
Code:
00:20:50.481 PBA[2702] Info (pb_steng_pb.c:3695 pb_PhoneConnectedIdleState_EventHandler)  pb_PhoneConnectedIdleState_EventHandler: PB_SYS_IGN_OFF_ON_EVENT received for device 1 in pbPhoneConnectedIdleState
00:20:50.481 PBA[2702] Info (pb_steng_pb.c:3282 pb_PhoneConnectedState_EventHandler)  pb_PhoneConnectedState_EventHandler: PB_SYS_IGN_OFF_ON_EVENT received for device 1 in pbPhoneConnectedIdleState
00:20:50.591 PBA[2702] Info (pb_steng_pb.c:1033 pb_dev_TopState_EventHandler)  pb_dev_TopState_EventHandler: PB_SYS_IGN_OFF_ON_EVENT SYSTEM_ACC_OFF for device 1 in pbPhoneConnectedIdleState sets ReadyForShutDown
00:20:50.591 PBA[2702] Info (pb_steng.c:1284 pb_TopState_EventHandler)  pb_TopState_EventHandler at PB_SYS_IGN_OFF_ON_EVENT SYSTEM_ACC_OFF in pbActiveState: STATUS_COMPLETE from PB_SYSTEM_ProcessIgnOff()
RADIO [CODES 686,729,802,1773]
Code:
00:20:50.788 RADIO_DB[729] Info (radiodb_interface.c:309 RADIO_DB_Open)    File exists in RAM
00:20:50.788 RADIO[729] Info (radio_steng.c:2890 radio_FMstate_EventHandler) Cleared successfully
00:20:50.853 RADIO_DB[686] Info (radiodb_interface.c:5416 radio_DB_UpdateMetadata) metadata =
00:20:50.853 MMUI_FMRADIO[802] Info (uia_fmradio.c:2536 UIA_FMRADIO_IsEuTau) UIA_FMRADIO_IsEuTau returns 1
00:20:50.853 BLM_DVD[1773] Info (dvd_vbs.c:298 DVD_VBS_Status_Response_cb) 0x4dda8=14=0x4dd08=24
00:20:50.853 RADIO[729] Info (radio_am_interface.c:152 cbSignalNotify) RADIO_AM_CLIENT:  audioFocusChangeEvent: streamType:Media
WIFI [CODES 2314]
Code:
00:20:50.913 NMSWIFI[2314] Info (nmswifi_events.c:248 nmswifi_EventsMonitorThread) message: <3>CTRL-EVENT-DISCONNECTED bssid=macaddresss reason=3 locally_generated=1
00:20:50.913 NMSWIFI[2314] Warn (nmswifi.c:1635 NMSWIFI_StopScan) Scan is already stopped on this interface
00:20:50.913 NMSWIFI[2314] Error (nmswifi_control.c:303 nmswifi_ExecCommand) NULL Pointers for ctrl_conn or ctrl_conn_unsolicited.
00:20:52.262 NMSWIFI[2314] Warn (nmswifi_common.c:454 nmswifi_StopSupplicant) WPA_SUPPLICANT was stop by kill
00:20:52.262 NMSWIFI[2314] Warn (nmswifi.c:522 NMSWIFI_SetMode) Interface is already in DISABLE mode
00:20:54.840 kernel[] Info (: ) [ 1254.853203] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Im not sure about that, but in any case with this you could search easily in the log system, 'greping' with some words :)
Maybe codes for logs, or the PIDs!
Could you check ?
