1 - 13 of 13 Posts
Hello all,
I recently went to upgrade to the newest AIO release, and I ran into a problem.
After it installed, the built in applications such as fuel economy and maintenance are greyed out and not accessible; and the newly installed applications such as video player don't open.
I went to uninstall the tweaks, and reinstall them, but both USB ports stopped recognizing anything connected to them.
I've gone through a few versions of the AIO tweak, and have never had this bug happen before.
After doing some research, it looks like the AIO tweak possibly gets rid of a file called libgstalsa.so and I have to SSH into the head unit and reinstall it? I'm not sure if this is correct, and I'm not sure how to go about the fix if it is.
Please help!
Connect to SSH
Log in as root / jci
mount -o rw,remount /
cp -a /jci/lib/libmc_user.so.org /jci/lib/libmc_user.so
reboot
What do you think if they don't have root privilege? Because the 56.00.513c and lastest firmware, the root account pass has been change to other (no one know what is it), and the ssh login prevent by firewall of CMU, and last thing, they never run ssh bring back before get the trouble.
If you have installed the SSH bringback, you can enter the JCI test 11 mode, enter the terminal. Terminal interface is directly ROOT permissions, do not need to enter a user name and password. Then enter the above command.
But I dare not 56.00.5XX installed SSH_bringback, it will lead to boot loop
So I kept it at 56.00.100
If his firmware version is 56.00.100 or 56.00.240, it can be roll back to original libmc_user.so.
But if firmware version is 56.00.513 or greater and he doesn't run ssh bring back script before, so may be imposible to fix this problem.
so, Without root privilege, we couldn't do anything!
Provided that you can enter JCI TEST mode
JCI test mode~terminal
Connect the USB keyboard
At this point do not need to log in user name password, is the root 权限
Enter the above command
You can change the current root password
But in 56.00.513 and greater firmware, the JCI Test mode was disable, so we can't use this method...!!!
1 - 13 of 13 Posts
