I have the CarPlay and cables and hub and put it all back. My issue is the bolt that holds the head unit in. I dropped the bolt that holds the head unit in, the one that’s about 10” or so inside the dash. Anyone know the size, thread, etc so I can try and get another one at Home Depot or Lowe’s?
Thanks
Sent from my iPad using Tapatalk
i upgraded my USB module to allow CP/AA last week.
While i did not take the measurements i believe it would be an M8 approximately 25mm (1 inch) in length.
The plus of HD & Lowes easy returns. so to be safe i'd buy M8 15mm, 20mm & 25mm .... back at your auto, start with the shortest one first. i recall ~ 7 full turns to get it tight. if the 15mm give you that many (even 5 will suffice) you will be golden. Tighten/Torque to 70 inch pounds force.
