1 - 14 of 14 Posts
Admiral Obvious
Found out today my car doesn't like to race very long in temperatures in the 117+ range.
What options do I have other than the super expensive cs one?
Heat is the enemy. I'd go all out with a bigger radiator and higher flowing fans, higher pressure radiator cap, lower temp thermostat and if temp is still an issue, work on some vents to get the heat outta the engine bay.
Admiral Obvious
i have it down to two.
KoyoRad for 364
or CS for 349
basied on the photos, workmanship on on the CS looks spotty vs the koyorad manufacturing
Koyorad comes with a lifetime warranty, CS has a 2 year (and CS does answer my E-mails so good luck with that)
i can add a fiberglass ducting to help with forced cooling
On that college budget
Our systems are already pressurized pretty high for an "economy" car. I'd say if you are in that much heat I'd worry about power steering and transmission temps as well.
Just can't go all out for a full session. Only would go balls to the wall half the session if it is that hot no matter the car. Not worth the risk. Must've been super slimy out there too
Admiral Obvious
power steering not that big a deal and manual transmission doesn't have a temp sensor, but the fluid gets changed fairly often so not that big a deal.
Full balz or none at all!!!
and it was greasy as hell as well, didn't help other cars where spinning out as well and leaving fine dirt on the track.
I'm just glad to see a speed3 being tracked. Hats off to you. Wish I had one to track. Be just more fun than it already is in my car.
The Turbo Guy
- KoyoRad radiatior
- Mishimoto universal oil cooler with thermostat
- Larger intercooler
- Don't go flat out after the car has been stagnant for awhile and the intercooler is hot
- OEM ducting should already be pretty good
- If that still isn't enough, you could get a custom tune with slightly retarded timing. It would improve knock margin and put less heat into the combustion chamber walls.
Admiral Obvious
Discussion Starter · #10 ·
- KoyoRad radiatior
+1
not a lot of room for that
CPe is pretty big
the over heated happened on track 7-8 laps in, being nut to butt on shelby GT may helped me
not really, there where louvers on the back side that got stuck closed due being dirty :/
i already have this, + has additional fueling to do just that. and according to Cobb, the set the fans to both come on sooner
^this. I don't recall anyone else offering a larger radiator other than CS. I think they have one in their Scratch and Dent sale.
Edge offers one made by KOYO, IIRC
Edit: Derp, just saw it's already mentioned. SMH
Reactions: sin_loki
Admiral Obvious
Discussion Starter · #12 ·
waiting this weekend to get time check compression / leakdown and see how i done fucked up the block. no sense getting a larger rad if the motor is cooked.
Yeah, gotta budget. But upgrading the cooling system would be good for the future though.
1 - 14 of 14 Posts
