1 - 8 of 8 Posts
MAINTENANCE MODE
SM2335192
id041200523600​
Note
• When in maintenance mode, the clearance between the disc pad and the disc plate expands.
• When the maintenance mode is completed, perform the electric parking brake automatic adjustment.
• With the electric parking brake automatic adjustment, the electric parking brake motor gear unit operation time is longer than normal.
Switching To Maintenance Mode
Caution
• When performing the procedure while the vehicle is on the ground, block the front and rear wheels using wheel blocks. Otherwise, the vehicle may move when the electric parking brake is released.
1.Switch the ignition ON (engine off).
2.Release the electric parking brake by pushing down the electric parking brake switch while pressing the brake pedal.
3.Release the brake pedal and then depress the accelerator pedal all the way down (past the kickdown switch on ATX model) and continue to hold it down.
4.Push down on the electric parking brake switch and continue to hold it down.
5.Press and release the push button start 3 times within 5 seconds. (OFF → ACC → IG-ON)
6.Verify that the brake control system warning light is illuminated in an amber color to indicate it is switched to maintenance mode.
7.Switch the ignition to off and release the accelerator pedal and electric parking brake switch.
Ending Maintenance Mode
2.Depress the accelerator pedal all the way down (past the kickdown switch on ATX model) and continue to hold it down.
3.Pull up on the electric parking brake switch and continue to hold it down.
4.Press and release the push button start 3 times within 5 seconds. (OFF → ACC → IG-ON)
5.Verify that the brake control system warning light turns off and the maintenance mode is canceled.
6.Switch the ignition to off and release the accelerator pedal and electric parking brake switch.
Do you know how to do the "perform the electric parking brake automatic adjustment"?
They don't seem to mention it with reference or maybe I just don't understand.
Update us on results!
I can go into and out of maintenace mode no problem but I did not get a chance to actually remove the brake pads and hardware on the rear as I am waiting for to get an update on "ELECTRIC PARKING BRAKE MOTOR GEAR UNIT REMOVAL/INSTALLATION" but if it does not get updated I might pay to get the online service manual for a day (online) to get some more details on that. I've seen a few videos of ppl removing the electronic parking brake hardware on other cars but I don't want to risk damage as I am a beginner amateur mechanic lol
1 - 8 of 8 Posts
