So, I dropped my car off at the local dealer to have them fit it with a new set of tires and they called me back recommending a transmission fluid flush $160. I was told there was no recommended intreval, but that the fluid was looking dark. I'm not sure if fluid needs to be changed or if they are just trying to pad my bill. I did a quick google search on the subject and found this:
For optimum protection, change the fluid and filter every 30,000 miles (unless you have a new vehicle that is filled with Dexron III ATF which is supposed to be good for 100,000 miles).
I have 34K miles, so maybe it should be changed, then again, they say if I have this Dexron III AFT, then I'm good for 100K. The manual says little to nothing on the subject. Anyone have some insight, I've got to call them back soon!
Thanks!
Thanks!
