What if it's perfect and runs like new again?
What if it's perfect and runs like new again?Maybe it’ll be fine, but what if it happens again? What if it’s never the same?
It’s honestly what I’m hoping for.What if it's perfect and runs like new again?![]()
My car has 19k miles. Honestly, I noticed for a little bit that jerkiness with the gears during slow driving but I always thought it was the trans hunting for gears. The past week or so I started hearing that chirp between 4th and 5th.@dagone12, how many miles are on your 2021? Do you remember any other symptoms that alluded to problems in the past?
Yeah, I am out of luck at my position. Rough shifts at times and 4th to 5th 'chirp' all the time.I might be posting this to late and if your hearing weird transmissions noises then it might not even help but this video fixed the weird transmission issues I had. The video basically goes over how to reset what the transmission learned and you have to "retrain" it in a way.
Was the chirping constant or only while changing gears. Currently I have a chirp noise I can't get figured out. However I haven't had any jerkiness in changing gears, it also seems to do it quite often not just changing gears.This is the last thing I’d ever expect to post on here, my transmission is going to get replaced - eventually. I drive a 2021 select sedan, automatic.
The last couple of days, I noticed a chirp at lower RPMs while changing from 4th to 5th gear. I took it in to the dealer this morning. Techs couldn’t recreate the sound so I asked to take them on a drive. Sure enough, I was able to replicate the sound and even get some jerkiness with the gear changes. They even recorded it on their phone.
Finally, I took the car home but they started the process of starting the case with Mazda to order a new transmission.
I am honestly bummed out. I avoided the Civic and Corolla since I didn’t want a CVT and this happened. Unreal. My question is, after it’s repaired and hopefully working properly, should I keep the car or just move on from it? I hate that my poor car is going to get molested and have a new transmission in it. Maybe it’ll be fine, but what if it happens again? What if it’s never the same?
I know. Long post. Sorry.
Only while changing gears (4th to 5th).Was the chirping constant or only while changing gears. Currently I have a chirp noise I can't get figured out. However I haven't had any jerkiness in changing gears, it also seems to do it quite often not just changing gears.
I can’t say seamless, like, I feel the gear changes but it’s a natural change like other cars. But it’s really smooth. Day and night. Even at the lower speeds.That's awesome. Congratulations. Is the car truly seamless / smooth, or just 'smoother'?
