I've owned my 2013 Mazda 3 Skyactiv Hatch for a few months now and since I bought it the traction control light is always on. Is this a common issue? Any ideas on how to fix it?
Axela AWD driver
What happens when you press and hold the TC button?
Does it go away? Does it flash?
Have you tried disconnecting the battery for 30 minutes?
If it's always on, there may be a problem with a speed sensor or ABS module.
Ditto it might be an ABS sensor on one of the wheels that needs to get replaced
see if you can get someone with an advanced scan tool to check it and see if they can pinpoint the problem.
A regular scan tool might just give you a generic error code.
From there see if you want to fix it yourself or have a shop do it
Nothing happens when I press or hold the TC button. I'll try disconnection the battery.
Should I take the car to the dealership to scan or find an individual mechanic?
Axela AWD driver
I suspect it's a wheel speed sensor(abs sensor).
It shouldn't cost too much to get it replaced.
If you're on a budget, take it to a local shop to find out what the problem is, then order the part online and replace yourself.
The sensor are easy to replace, or it could even be just a lose connector.
