1 - 10 of 10 Posts
Hi all,
Any ideas would be appreciated. Just finished installing the new hub and cables but now the top usb port (the CarPlay one) does not recognise the phone at all. The bottom one works as expected -> phone charges, says USB 2 connected, can select in entertainment sources to play music. Plugging in to the top one does nothing. Android Auto and CarPlay options in the Apps section remains greyed out.
Visually inspecting the pins both at the back of the CMU and the back of the hub shows no pin bending etc. Also visually inspected the USB ports and they look identical. I've tried unplugging and replugging, wiggling the cables. Unfortunately I can't swap the cables to the opposite port to rule out that a cable is faulty as they have specific moulding.
Is there something I'm missing? There must be a fault with either the cables or the new hub. Not sure how I can get this fixed...
Do you own a multimeter? With that you could check (e.g. at ohm or diode setting - see youtube-video), if the cable itself is OK. De-installed cable, Multimeter to lowest ohm setting: Pin 1 on the one end to pin 1 on the other end of the cable. If the multimeter shows some value other than .1/-1 or 0 the string of the cable between these pins is OK. Repeat with the other pins.
If the cable is OK, it might also be that the USB hub is faulty. You also might try the same as for the cables with the usb hub... De-installed usb hub: Multimeter to the usb side of the hub and choose a pin in the usb port - eg. GND or +5V (as seen here). On the other side of the usb hub you probably have to check each of the pins if there is a connection (ohm showing in the multimeter).
Thats one way to check it by yourself. Alternative might be to go to the selling dealer and tell him cables and usb hub is not working properly and you want a replacement.
You first installed FW 70 and then did the hardware install, right? Because thats how it has to be done. If not, please re-install the old usb hub & cable, update to FW 70 first and afterwards install the new usb hub & cables. Then try again.
Hey thanks for the advice. I don't own a multimeter but might pick one up and try it tomorrow.
Yep I checked the FW and its definitely on 70 — and apple CarPlay and android Auto show up in the 'Applications' section of the infotainment screen so I think that side of things is all good. I wonder if it would be worth reinstalling it.... not sure if that's even possible.
Discussion Starter · #4 · (Edited)
Just tested both cables and they both exhibited the same behaviour: on diode setting the multimeter returned ‘002’ or ‘001’ (default display was ‘1’) on each corresponding pin of each cable as well as on the bigger outside metal bit. I’m guessing that means the cables are fine as both the working one and he not working one had the same behaviour. The hub is harder to do but I’m trying now. Again will compare the working port to the not working port to see if I can find a difference.
Here's the result of the hub testing. Sorry about the terminology as I have no idea what I'm looking at…
The bottom left and bottom right pin on both ports seems to function pretty much the same.
The top left pin functions similarly but the pin in the working port has a value double that of the pin in the non-working port.
The top right pin and the metal bit on both ports is very different however - the working port shows a high value on pins 2 & 3 but the non working port has no values at all on these pins...
Not sure what this says, are any experts able to analyse?
I doubt I'll get a reply from this old post, but I have the same problem and am wondering if you arrived at a solution.
I upgraded firmware, then installed the USB retrofit kit. Everything works except USB1 is not recognized. I double checked the cable connections and they are secure. I've tried multiple phones and different cables, but USB1 doesn't charge and doesn't recognize phones or flash drives. USB2 works just fine, but I can't run AndroidAuto/CarPlay through that port.
Any thoughts?
Any thoughts?
I’m in the same boat we might have to replace the cmu .
Why the expensive cmu? First I would replace the cheaper AA/CP hardware, which might be faulty. There are AA/CP kits/set (mainly from Aliexpress) which look like original, but are not (and do not work). Buy original kit/set e.g. of a mazda dealer and test again.
I have a similar problem, except I installed genuine mazda parts as soon as they were available, a few years ago.
everything has worked fine until a week ago, where CarPlay was hit and Miss for a few days, and now USB1 does not work at all. Rebooted the phone and the car, and tried a handful of different cables.
Any advice before I schedule something with Mazda?
1 - 10 of 10 Posts
