Maybe you should go back to square one and check a few things.......
If you’re reading this, chances are you appreciate the thrill of turning a fast corner as much as you enjoy laying down a big patch of rubber. There really is more to life than living it a qu…
speed.academy
A larger rear bar increases the virtual combined spring rate, so it "tightens" the suspension. In a turn, the larger bar limits weight transfer to the outside tire and so limits grip, reducing the tendency to push, or understeer. This does make the rear end feel looser. Corner weighting is entirely different and has no real bearing on the sway bars and vice versa, other than you can cheat a bit and preload a bar to favor turning in one direction vs the other.
If the front outside tire is being overloaded you can tweak the suspension further to make the rear end a bit looser, or you can add a larger front bar if allowed. There is a line you don't want to cross to avoid snap over steer.....
I know very well how tires fit, what they fit and why. I also know what tires to use to get the best grip from a particular rim. Those numbers published on TireRack are industry standards for safe use, nothing more. There is no "proof" of anything there. If you were to actually read the specs and understand them, you'd see than your tire, a 225/50/16, has a section width of 9.2". Now subtract .2" from that because you are going down .5" from the measured 7" used for that tire when calculating industry standards, and you end up with a tire that is
9" wide and has a 7.6" tread face on a 6.5" wide rim. That tire is going to roll off the tread face onto the shoulder in a hard corner and you will lose grip because the sidewall will not provide sufficient support.
Here is a pic I found that shows the problem of using a rim that is too narrow for the tire. I'm sure you can figure out whats happening here....and the result
Its also going to have kind of sluggish turn in also compared to a proper width tire. The rim will turn, the sidewalls will flex, only then will the whole tire will catch up. Squissshhhhhh....
Most guys with smaller cars use 185s or 195 on a 6.5" rim for best results. 225s are for street cruisers who don't want to feel the bumps.......
