Ok you 3rd geners post all your pics of aftermarket wheel/tire combo's here. No 1st or 2nd gen pics. Lets stick to pictures only. Make sure to state your wheel/tire specs.
It's our custom composite M3-specific Relocator based on the prototype I did more than a year back. Have shipped some to neighboring Sg. I'm currently arranging w/ a buddy in Jersey to help get these shared in NA.G
Hey bro.. Just wanted to ask how all these 3's relocated their front license plates? What type of bracket was used? Thanks, cheers!
Fitting won't be a problem, but on full load, you'd likely rub on +35 w/ either of those tire options. Camber & fender roll would help.Can someone tell me if a 18x8.5 et35 on a 225/45-18 or 225/40- 18 will fit? Stock 2015 Mazda 3, not lowered
That's the same1. They'll soon be made available in the US.Not sure where to get them!
Is this what you're looking for?Do you happen to have a pic from the front or back of the car at a sharp angle showing how flush the wheels are to the fender? thank you!
Those look sick!!! Should request an Aimgain bodykit too![]()
AIMGAIN GIIM's
19x8 +45 (15mm spacer)
19x8.5 +45 (10mm spacer)
Back on 2012 ms3 wheels and 25mm spacers front and rear.
Yes! Thank you!Is this what you're looking for?
Front:
Rear:
Here's my new wheels Varrstoen ES2 (18x8.5 +45mm) on Toyo Extensa HP (225-40-18)
[/URL][/IMG]![]()
[/URL][/IMG]![]()
[/URL][/IMG]![]()
[/URL][/IMG]![]()
Ewww can't believe how stock basic my ride looked last year, as far as the tires goes 235 would be fine you won't have any issues with fit with your prokits, the picture posted is when I had prokits so obviously you can see that there aren't any fit issues with that setup.Hi @$lickology,
I ordered some wheels that have a same size as what your Varrstoen's have (18x8.5 45 ET). Just curious on how you selected your tire size.
Do you think 235/40/R18 would be ok? It looks like it might fit under there but I am not sure. Just thought I would get your perspective since you have the same size rims.
The wheels that I have ordered are on backorder :frown2: so that does give me a little time to mull over the possibilities with tires.
I should also mention, I have the Eibach Prokit so obviously that will factor into the clearance.
Thank you for any input/feedback that you can provide!
Thank you!Ewww can't believe how stock basic my ride looked last year, as far as the tires goes 235 would be fine you won't have any issues with fit with your prokits, the picture posted is when I had prokits so obviously you can see that there aren't any fit issues with that setup.
What wheels did you get?
When are you getting your tires? I would certainly like to see how they look once you get them set up.I have RX8 wheels 18x8 ET50 and I am going with 235/40. I might add some spacers too and I will be getting it lowered. Was going H&R but now looking at coilovers.![]()
