1,781 - 1,800 of 6,600 Posts
which car do you u have?
55 is for cx-5 , I think.
Greetings everyone,
I'm having a couple challenges with the procedure. Would someone mind to provide me some feedback on the below?
- I copied the two firmwares and went to my Mazda's "hidden" system menu option 99, tried to apply the firmware. The failsafe applied successfully whereas the reinstall is giving me an "cannot validate certificate" error message! Am I missing something? I tried downloading the file again and got the same error.
- Besides extracting and copying the tweaks files to the root directory of my USB key and plugging it, do I have to "trigger" its execution with something or does it happen automatically after some time? Can't seem to get anything running.
Many thanks for your replies.
W.
Ok this is the final tweaks file for applying the basic hacks:
https://mega.co.nz/#!8o1XXKLR!wh_CuoZcVV9FhQZJiiCAgcsslMGwnm0dAPmTSLjDowM
I've shortened the time it takes to execute by bypassing all the other logs and added a dialog that lets you know when the tweaks have been applied. Afterwards check your command_line.log file for something like this:
Setting Speed Restriction Configuration to 'disable'
Setting BUS_BCM Speed Restriction Configuration to 'disable'
that means it worked.
Working on getting a plug and run background changer. someone else may beat me too it as its easy peasy.
enjoy.
Very nice!
It's been a while since I've dug through the files and my mind is fried from building a bunch of servers for work... So, I apologize in advance if I sound like an idiot here... Is it possible for the auto-tweak to include the changes to re-enable the WiFi?
I managed to make the video play, but the second time I tried it won't. Gave me this error:
Does anyone has a clue?
Something else, how can I stop the video playing :) ?
Excuse the delay in answering your question.
Suppose you have 1 mp3 on your USB, Mazda will identify another mp3 from the mp4 file, play and pause it, then run the line (code/script?). Tell us if it works.
The only way I know to stop the mp4, is by Ctrl+C. haha
Exciting post!
North America Firmware 55.00.650 available!
Failsafe:
https://mega.nz/#!do0TgBKJ!GWlxC-92fx2GB-ufYV3F-ZDvzSAlB4hhVIi7d1e4QVo
Reinstall:
https://mega.nz/#!5x8zTIyT!rv6liwUZ3ZIBTC3BWUgoB93aG_MzqrEESI09ufdOS2I
Someone should run a JS file comparison to see what bugs were fixed. I checked the build and the p@ssword is still good.
Also as a bonus (im lazy):
plug and auto apply tweaks:
Watchdog disable
Warning Dialog timeout
Speed Restriction Disable
UPDATED with fixed tweaks script file that has been re-worked and tells you when tweaks are done.
(just copy all in zip file to usb and plug it into running infotainment, wait for like 10 min until you see a screen that says its done).
This obviously is due to the major effort you guys play here, lets keep digging and keep making great stuff.
* disclaimer, the auto tweak file is just a sh file "tweaks.sh" that has line by line the tweaks, you can remove the ones you dont want. Also dont run it if you've already applied these hacks, it should be done on new installs. I would like to point out that this can be made far more user friendly by echoing out the results from the tweak command calls to a jci dialog so that you know what completed or didnt. I didnt put any time into making it, just didnt feel like connecting the car to the laptop again.
And finally. I am not responsible for anything you do with these files.
Enjoy
​Hi blakehaas.
Thank you​ again for your post .
I installed successfly 55.00.650 NA N . up from 33.00.700 JP.
You guys always be notice the two files.
jci/settings/config​ration​s​/m​az_​cmu-root.xml and ​blm_settings-system.xml
​These file​s​ assign​(set)​ your​ ​region,​ ​language,​ ​and ​a lot of ​vehicle settings​ infomations​ from MMUI messages.
​(and also set navi voice from which speaker )​
​Region ex​.​) NA is ​2​ , JP is 5
In order changes in this file to take effect,
the /mnt/data/com/jci/cpp/settings/XXXXXXXX.bin file should be removed and the system should be reboot.
Cheers !! :laugh2:
I'm confused is v55 for Mazda 3's or just cx-5's?
Version number does not matter, here's an example Mazda 3 with version 51.00.300 Value is number CMU
And Mazda 6 as with version 51.00.300
CX-5 Update V55
Hi Joe,
Thanks for the prompt reply. I have a 2016 CX-5 with the premium and navi pack.
After going in to the "hidden" 99 area how did you apply both the Updates?
Also like rdriggett can you let me know if you found any of these changes.. Cheer
Do you know if it fixed 128gb Music load time?
Do you know in the navi area, if it change the Speed sign in to actual speed your going?
Any one able to shead a little light on the CX-5 changes to V55, Running 51.00.350
Quote:
Originally Posted by rdriggett View Post
Flashed it on my 2016 cx5 and it works like a charm!
Every time your trying to play the video, it changes the Name from /mnt/sdb1 to sdc1 sdd1 sde1 and on. if you reboot the system it goes back to /mnt/sdb1.
Can some one take a screen shot of the "/js/systemApp.js" when this code is applied "
chmod 755 /jci/gui/apps/system/js/systemApp.js
Does this disable the Disclaimer or just make the time smaller? Already when in with winscp and made the time from 3500 to 0000 but still come's on.
How to you run an autorun? Apply_tweeks_USB
I put all the files on a blank usb but after leaving it for 10 nothing has happened.
Also can any one find out how to take out all the items in the HD Traffic app.(Where are the .png's and delete them. It would be nice with out that crap as it does not work down here. I want to see my own custom screen witch I have already put in the /jci/gui/common/images/background.png
You cant make the time 000, it expects a time and there is a workflow that is designed in such a way for it to exist. The tweak if you look at the command like (all tweaks available here on the forums and here: start [Mazda3Hacks])
drops the time to 100MS which is 1/10th of a second. Removing it all together would require a lot of manipulation of the code which can make the system break or be unstable, not to mention make it much harder to revert.
As for the auto run tweaks, you need to extract all of the contents into a FAT32 formatted usb and be on version 33 or higher.
Thanks Blakehaas (Doing an Amazing Job)
Ok I'm looking on the Mazda 3 hacks and it does not say anything about how to apply the code.
In terminal do you apply both of these?
1 mount -o rw,remount /
ENTER
2 chmod 755 /jci/gui/apps/system/js/systemApp.js
ENTER
And now reboot the system and the disclaimer will not show?
where would I add this in the script ( 100MS ) if I manual add it in ?
I have formated the drive to a Fat 32 on my mac and dragged 4 files
cmu_dataretrieval.up, dataRetrieval_config, jci-autoupdate, tweaks.sh.
I also have also tried drag and drop the new cmu150_NA_55.00.650A_reinstall.up
and it also does not autoplay. Must be missing something.
Any thing on the HD Radio side? I would assume that if i remove the .png file it would not show.
ENTER
ENTER
You need to be careful doing these changes if you're unfamiliar with this stuff. You can easily cause your infotainment to go into bootloop.
Read the instructions carefully, there are 3 steps.
The last step is shown for version 31 and for versions 33 and higher.
as for the update file. You need to follow the "How to Perform a System Update" instructions which are also listed on the mazda3hacks site.
Mirror here:
start [Mazda3Hacks]
Hey guys,
If you want to change the background fast you can modify the tweaks.sh file and add in
mv /jci/gui/common/images/background.png /jci/gui/common/images/background.png.old
cp /mnt/sd?1/background.png /jci/gui/common/images/
first line moves the old background. Second one copies the pic from the root of the usb.
as far as playing videos from the script I cant seem to get it working :S
Mirror here:
start [Mazda3Hacks]
LOL ok I'm not trying to be stupid, but if I look at this screen I do not see 3 step's. 2016 CX-5 running V51
My system already says -->
I see no steps. can you spell it out for me please.
what i see -->
// Disclaimer
systemApp.prototype._displayedDisclaimer = function()
framework.sendEventToMmui("system", "DisposeIntroVideo");
if (this._disclaimerTime.reset)
this._disclaimerTime.reset = false;
this._disclaimerTime.remaining = 3500;
if (this._disclaimerTime.remaining < 0)
this._disclaimerTime.reset = true;
framework.sendEventToMmui(this.uiaId, "Timeout");
Hey guys,
How are you getting this to work.( Anything ) I'v tryed Mazda 3 and a CX-5. This is my USB Pick Windows.:surprise:
Also with the Video not working. I was able to use IPHONE,HOTSPOT,ITERMINAL,IP & I'm in. From there I put the code in to play the video but when I disconnected from HotSpot or terminal it stops the Video. Something with maybe a ping back and forth needs to be stopped. Also found that every time you play a video the sdb1 changes and starts going up. Having the sd?1 does not work for me. Also best to make your videos 1,2,3,4,5 instead of the full name.
Have you tried doing a full fat32 format, not a quick format?
I just ask because my car is very picky about the usb drive I use for my updates. For whatever reason, with each update, I have to give it a fresh full format, copy the files and go straight to the car. If I modify anything on the USB drive, my car will probably throw crap at me.
Using a 64gb USB. Gonna change over to something small and see what happens.. Thanks
Still cant figure out what I should do with the Disclaimer. Does the code disable it?
What do I put in terminal to make this work? Please let me know, don't want to put my system in boot mode. lol
ENTER
ENTER
What should the System file look like after mod?
